Lexmark C540N PROD SPECS TBD Printer Logo
Posted on Mar 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
942.02 Service Yellow TMC Sensor error showing
Gerrit Jan
Level 2:
Champion:
  • Lexmark Expert 217 Answers
  • Posted on Mar 09, 2011
Gerrit Jan
Lexmark Expert
Level 2:
Champion:
Answers
217
Questions
Helped
144317
Points
346
Remove the toner cartridge, and inspect the lenses on the toner meter cycle (TMC) card.It is positioned on the right side of the toner cartridges
Are the lenses blocked, or dirty? Clean them
If damaged replace them
1 Related Answer
Anonymous
  • 1087 Answers
  • Posted on Jul 14, 2011
SOURCE: What means "943.02 Service Black TMC Sensor"?
A 94x.xx TMC Error indicates that the printer has failed to detect the Toner Metering Cam for a specific cartridge. This error typically occurs when the cartridge or developer are misaligned or incorrectly seated
Please click on the link http://bit.ly/ozldpC to see instructions on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
tip
How To Remove 077-100 Error in Dell 3130cn Printer?
This is right that error 077-100 error is belong to Registration and or Exit sensor.
But if the yellow toner cartridge doesn't run so there will jamming the paper and the printer shows the error (077-100).
Actually i solve the issue after three days when i guessed and checked the yellow toner cartridge it was tighter than others.
So i replaced the yellow toner cartridge and solved the issue.
943.02 Service Black TMC Sensor error
The best way is to call the company's technical dept.
C544dn printer - getting code: 941.02 service magenta TMC sensor
Please try the steps provided below.
Step Action 1
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page.
Did the error message return?
Yes: Continue to Step 2.
No: The error is resolved. 2
Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Power on the printer/MFP again and print a test page.
Yes: Continue to Step 3.
No: The error is resolved. 3
It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
Did the error message return?Yes: Continue to Contacting Lexmark.
No: The error is resolved. If the toner and/or developer were not near the end of their working life.
You can also refer to this link: http://bit.ly/kecjEM
2answers
THE 942.02 Service Yellow TMC Sens message is in the screen. What does it mean. It will not let me print
Error indicates a problem with the Cyan toner cartridge/developer. Try the following steps:
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page. Did the error message return? Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Try printing another test page, verify if you're still getting the same error. It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
For further assistance, please contact Lexmark Technical Support Center.
I have a lexmark c782 office printer that is showing a code of 942.05 service yellow tmc sensor what does this me
The error indicates either a defective yellow cartridge metering cycle or a sensor problem that usually requires service. But you can try replacing the yellow cartridge first. If problem continues, I recommend you contact Lexmark technical support or your authorized service provider for further assistance. Thanks.
Unable to get it connected
Is this the RDS-TMC?
Try resetting the navigator (using a paperclip in the reset hole in the bottom of the device). Then plug it in again and see if anything's changed. Remember that the antenna must be connected to power for it to work.
Are you seeing the vertical display on the right-hand side of the screen?
If the thing is constantly searching but never showing traffic updates, it's possible that you don't live in an area that has active RDS-TMC broadcasts.
"No disc" error message
Slicerro, You haven't fulfilled the problem request!!! But here is an answer to your question click http://denondj.com/download.asp
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
jdthefixer
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
