Canon PIXMA MX700 All-In-One InkJet Printer Logo
Question about Canon PIXMA MX700 All-In-One InkJet Printer
The print head is stuck on the right side and I get error code A680. Printer is a Canon Pixma MX700 series.
Robert cruse
    Master:
  • Canon Master
  • 336 Answers
May be the canon printer printhead is not installed properly. Or maybe the canon printhead not working due to some internal errors in the printing device.
You can fix the canon printer printhead error:
·Reset the canon printer
·Clean the print head, if it inside the dust
·Make sure your printhead not damaged, if it is then replacing it with new one
Read more troubleshooting steps to fix the canon printer printhead error.
Posted on Oct 13, 2022
Kenneth Weimer
Tossed the Printer in the Trash Can. Goodbye Canon
Anonymous
    New Friend:
How did you fix this problem?
Posted on Jan 19, 2011
My Canon MP520 has a 6A80 error and now the printer head is also stuck on the far right side.
6A80 error is an APP position error caused by the APP motor during the purging operation as the printer starts up. Canon states that one of three components is likely to have failed, the sheet feed unit, purge unit or logic board. All of these will be almost impossible to get as a spare part. The only thing worth trying is an EEPROM reset that can be done using the service manual. Get a copy here: http://www.tradebit.com/filedetail.php/4981053-canon-pixma-mp520-printer-service-manual
What does error code 5c00 in a canon mx700 printer mean?
Hi, 5C00 is a purge unit error, the purge is the cleaning unit on the right where the print head parks when shut off. If paper or something is caught in there you get an error, also ink build-up can stop it as well, a damp Q-tip will clean some of the ink away, if it doesn't help you need a new purge assembly.
Hope it helps.
Thanks for using fixya..........
2helpful
2answers
What does an error 5200 mean?
(1) With the printer turned on, unplug it
(2)Open the top and bring the ink cartridge holder to the middle
(3)Raise the gray bar and remove the print head assembly with the cartridges in it
(4) Lower the gray bar with the head missing and close the top with the head out
(5) Restore the power,wait til the printer wakes up
(6) It will tell you to put in the cartridges
(7) Restore the print head, close the top and the printer should resume working.....
it is a printer head error and some solved it that way ..after you do that it will resume the function and work ..
_________________
1helpful
I received an error code 6A80
Solution:
  • Switch the printer OFF
  • Press buttons 1 + 2 + 3 and 4 (simultaneously using four fingers)
  • Keep pressing this four buttons for 10 seconds
  • Release the On/Off button (number 4) (Keeping pressing the others)
  • After a few seconds (when the printer go ON), release buttons 1, 2, 3
Pixma MX700.Error code 5100 . Paper from rear printing stuck in printer. Please advise.
Hi You can Try
Error Code 5100 You need to get ant bits paper from it first, no easy way just go to get in to it and get it out try turning the rollers by hand.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
2helpful
Error message 6a80 mx700 printer canon what is this?
Hello
Ok, the error code you are getting refers to a paper jam, which the paper is usually torn from the big piece and stuck, you need to have a good lok to find it.
Most probably the paper was ripped inside, and one piece is stuck somewhere on a sensor. Usualy is the purge unit that clean up the print head, and it's located inside on the right side (printhead parking place).
Take a torch, lift up the scanner unit, with the unit ON, wait for the print head to come in the middle, move it to left to make more room, and check the right side, inside the unit.
Kind regards
Andrea
1helpful
2answers
My Canon Pixma Printer MX700 is near new and the screen is showing Error Code 6A80...and the alarm light is flashing.. Does anyone know what the problem is?
According to Canon there is a way to reset the printer.
Just go to this link and this should help.
http://fix-your-printer.blogspot.com/2009/06/error-code-6a80-on-canon-printers.html
If you need further assistace, please respond to this post and I will help you.
Thanks for using FixYa
asnowman
4helpful
2answers
Canon pixma mx700 error code 5010
5010 is a scanner error from the scanner on top. Canon has no parts for these and you can only replace the entire top of your machine. If you can get it apart, you might clean and lube, but it's not made to be opened.
2answers
Cannon Mx700 error code 6a80.
It is because of Purge unit can be damaged or stuck. Probably you have to pulled apart the printer and check the purge unit.
2answers
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Clive
Clive
old marine
old marine
