Panasonic PT-47WX53 47" Rear Projection HDTV Logo
Posted on Mar 02, 2010
Blue outlines on screen. not a screen burn or convergence problem
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 30 Answers
  • Posted on Mar 02, 2010
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
30
Questions
0
Helped
5894
Points
41
I am not familiar with that particular model but most are similar.
It may need the blue focus adjusted. Most tv's have some type of automatic focus. If the blue is out of focus it can "bloom" beyond the red and green. There should be a focus block with 6 adjustments (2 rows of 3) behind the speaker cover. I wouldn't mess with the one labeled screen or block. Adjust very carefully. They are usually in the order Red-Green-Blue with the focus on the bottom row.
Magic focus runs half way & stops &showes a #4 ? one side of a face has a green outline the other side red
You may have a burned out convergence chip. But first, if you haven't already, you can try service mode to adjust convergence. Press the Magic Focusbutton, and then press it again to stop it, and then press the Statusbutton on your remote. Here's a link to the manual convergence procedure (scroll down). Warning-- When I did this the set got stuck in one of the adjustment screens. I had to remove the bottom front panel of the TV to reach the "little blue" reset button to get back a TV picture. But I think this is worth trying before replacing parts.
Model R52Wh74 RCA and we have blue color all on the screen
Have you tried to do auto convergence and see if that helps? If not try manual convergence adjustment
Projection lights don't line up
Sounds like your convergence chips have failed. This is a common problem. You can get a repair kit from www.TvRepairKits.com .
HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
3answers
Convergence controls
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
2answers
2001 Philips 43P8341Blue outlines on images
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
