I'm trying to connect the wii to the component jacks the green, blue, red input 2 and the screen...
(More)
I'm trying to connect the wii to the component jacks the green, blue, red input 2 and the screen keeps flickering(as if its on the wrong channel) audio is fine but it won't show a picture I have model hitachi ultravision 53sbx59b
I have a Hitachi 53SBX10B AND SOMETIMES IT HAS COLORED LINES ON THE SCREEN AND I CAN TAP THE TOP AND...
(More)
I have a Hitachi 53SBX10B AND SOMETIMES IT HAS COLORED LINES ON THE SCREEN AND I CAN TAP THE TOP AND IT GOES OFF BUT COMES BACK ON WHAT COULD BE THE PROBLEM
Hitachi LS DMP850N 8GB Multimedia Player display problem. I can view 17 albums through My Computer...
(More)
Hitachi LS DMP850N 8GB Multimedia Player display problem. I can view 17 albums through My Computer which have been sync through Windows Media Player. I can only view 13 albums on the display screen on my player. Help, David
tv comes on and all factory setup shows display but no picture or sound on any plugin hookup at rear...
(More)
tv comes on and all factory setup shows display but no picture or sound on any plugin hookup at rear and front video in or out.
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able...
written by misenhei
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
