HP Pavilion a305w (DM181AR) PC Desktop Logo
Posted on Feb 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CD Rom wants to remain in Open position and doesn't read cds
The CD Rom wants to remain in the open position. If I put a disc in it and please close, it looks like it might work then re-opens again. Any suggestions as to what it might be?
Anonymous
Level 2:
  • Expert 76 Answers
  • Posted on Feb 25, 2008
Anonymous
Expert
Level 2:
Answers
76
Questions
Helped
36065
Points
153
There might be something jamed or lodged in the CD-ROM compartment which would be preventing it to close all the way so it wants to stay open.Hope this helps =)
My cd rom drive plays cds rips cds reads and does cd rom programs but will not let me burn cds any more..... i was able to burn cds just fine before???? please any help?
Have you tried reseating the CD rom;verify all the connectors are securely fastened. What type of Dell is this; a tower, desktop, or laptop? If you know how to open the case then proceed with reseating as follows:
First power down the system
After opening the case
locate the CDROM
If this is a new system it is probably connected using a SATA connector (black cable with a blue connector and power connector.)
At the back of the remove each connector then reconnect the cable
The SATA or Parrellel cable has a connector at both ends so trace the cable and re-seat the connector on the motherboard as well.
close the case
boot the system back up
test the cdrom
1helpful
Re. TEAC CD-224E, model version -B66. The drive will only open when inserting a pin in the release hole. When a disc is inserted and the drive closed the computer can not read it, the disc keeps...
This is an indication of mechanical failure of some part of the ejection mechanism. Since they are more expensive to fix than the drive is worth, replacement is your best option.
In addition, since the CD remains spun up and the activity light doesn't go out, there's probably something else wrong with the drive in addition to the failed ejection component.
It doesnt open and cant read the cds inside.
Remove the cover lid and look inside for anything jamming disk tray, problem may be very simple once you look at this. change out some of the cds.
I can't burn anything with my DVD/CD-ROM but it reads dvds and cds
first reinstall the operating system and then you use either nero 6 or NTI CD? DVD maker
1helpful
Cd tray stays open
There could be damage to the tray contact switches
(these tell to the control unit the position of the tray - open/closed), so that the control unit can start/stop and reverse the direction of the tray ejector motor.
These contacts are located somewhere underneath the tray (usually near the front unit cover), and since you mentioned that the tray was bumped while it was open, it is possible they were damaged. Also, the behaviour of the tray suggests that the control unit can no longer tell whether the tray is open or closed so it operates the tray motor in a wrong manner, which, again, points to these same contacts as the possible cause.
Repairing the contacts may be a somewhat delicate procedure, first you need to locate them (it may require partial disassemby of the tray mechanism), if they are bent a pair of tweezers might do the job, if there's hard damage, it's probably better to replace them (scrapped CD ROM units or a dead CD unit might be a good source, they just need to be of the same dimensions).
There may also be other causes for this malfunction, i just mentioned the first thing that i would check.
Hope this helps somehow.
regards
3rq8 (Triarcuate)
CD ROM does not recognize that a disc is inserted -Dimension 2400
i think your cd rom is damaged. you can clean the cd rom lanse or you can buy a new cd rom or your cd is damaged.
Is cd-rom and dvd-rom different?
CDROM drives can only read CDs while
DVDROM drives can read both CDs and DVDs
If you need further clarification please do contact me.
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
No playing CDs
go to website of bell computer 1. find the latest BIOS and download it to your computer 1. find the latest driver for your CD model and download it Good luck!
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
