I have a lexmark x203n with error codes 931.01 and 931.02 No first H sync and print head lost. Any help as to what to do about this? Thanks in advance!
I do not think resetting to factory defaults will solve this problem, anyhow this is how to reset the X203 to factory defaullts. Turn it off, Kepp press?d keys "check mark" and "right arrow". Turn printer on, wait until some dots show in the panel and release the buttons. Enter CONFIG MENU, browse right/left until you reach Factory Defaults, press Select / Check mark. Done.
Thank you for contacting FixYa with your printer error.
What the error means A Printhead Error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly. NOTE: On the E250d(n) models, all service errors are signified by the flashing of all of the lights. To determine if this is a printhead error, quickly double-press the button to see the secondary code. If the !, , and lights are the only ones blinking, a printhead or a motor failure is indicated. For more information on deciphering the error lights, click here (PDF file, 255KB). Follow steps in this link to clear the error.http://support.lexmark.com/index?page=content&locale=EN&productCode=LEXMARK_E250D&segment=SUPPORT&userloc
According to the error code, http://pixma.ulmb.com/?p=226, the error #5200 means "Print head temperature rise error".
Some
of the nozzles of your printer are clogged. The print head will
overheat because it does not have ink going through the nozzles to cool
it. But
you continued to print repeatedly, the print head may have been
destroyed due to overheating.
These error codes indicate a problem with the mirror motor circuit in
the printhead assembly or the mirror motor cable to the system board
cable or system board assembly. Check the continuity of the mirror
motor cable connected to J5 on the system board. If incorrect,
replace the cable. The voltage at J5-7 measures approximately
+24 V dc. If incorrect, replace the system board. If correct, replace
the FRUs in the following order:
• System board
• Printhead assembly
I guess you're getting an error message which is normally one of the below (causes underneath)
Error Code 931
No first HYSNC Signal
Error Code 932
Lost HYSNC =
These errors usually indicate a
failure in the HYSNC signal to the
printhead. Check the continuity of
the cables connected to J3 and J8
on the engine board. If incorrect,
replace the defective cable. The
voltage at J8-4 measures
approximately +5 V dc. If incorrect,
replace the engine board. The
voltage at J3-7 measures
approximately +24 V dc. If incorrect,
replace the engine board. If correct,
replace the printhead assembly.
Error Code 934
Mirror Motor Lost Lock
Error Code 935
Mirror Motor unable to
reach operating speed =
in the printhead assembly or the
mirror motor cable to the engine
board cable or engine board
the mirror motor cable connected to
J3 on the engine board. If incorrect,
J3-7 measures approximately
engine board. If correct, replace the
engine board
printhead assembly
