Could not find anything directly about a Canon P26-DH III calculator but, here are steps I found for a similar model. Please let us know if this does the trick for your situation or not. Thanks & Good Luck.!
Installing a Replacement Roll
Move the power switch in the upper right corner of the calculator to the "Off" position. (or wherever it may be on your model)
Push the wire roll holder back so it protrudes from the back of the calculator. Place the replacement roll on the holder so the paper's end extends from the bottom of the roll.
Cut the paper's end diagonally and insert it into the slot in the back of the calculator.
Step
Move the power switch to the "PRT" position to turn on the calculator.
Install paper roll with end coming up from rear. Insert end of paper into slot at back of calculator until it stops. Then press feed button until paper advance thru slop at top.
For loading paper into canon p23-dh v is to cut a piece of index card to the length of 3 inches and to the width of the paper you want to load. Tape evenly to the end of the paper roll and put into the ****, pushing gently in and at the same time pressing the 'Feed" button. It will immediately feed since it is firmer than the Poat-it paper.
While looking at the front of the P23-DH printing calculator. Fold down the
paper holder and turn the calculator back around to face you. Then, cut the paper
on the roll straight across. Then, feed the paper into the slot in the back of
the calculator. Turn the calculator on to the print mode. Then hit the "feed"
button. The paper will feed through and you are ready to go.
The calculator wouldn't take the paper but when he cut the corners off the paper to make a blunt "V", it grabbed the paper right away and pulled it through.
Put paper roll on paper arm with the end of the paper coming down from behind. Cut paper on a diagonal. Insert the paper into the **** at the back of the calculator. You need to really look to see it. Use the feed button to feed the paper through..
While looking at the front of the P23-DH V printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then cut the paper on the roll straight across. Then feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed thru and you are ready to go.
how to replace paper roll
