I have a Ricoh Aficio cl3000 networked via USB to my airport extreme to my iMac 3.06 Ghz. When I print the data in light blinks 3-4 times and then stops and the print job deletes from spool. I have tried a direct USB connection to the printer with the same results.
Does your Toshiba have a wireless adapter? If so, you can set up a home network, if you don't already have one. If no,Does the iMac have a VGA or HDMI connector? You can connect via a adapter cable, Vga to HDMI or a HDMI cable, depending on the iMac connections.
go to the control panel, select printers and double check if the Ricoh Aficio CL3000 Laser Printer was selected as a default printer. you can check it by right clicking the printer name and choose set as default.
what program are you trying to print from on the Mac? I ran into a similar problem with Quark. here's that solution: went through some Quark forums on line and read everything about printing problems with Quark 7 or 7.3. Most posts blamed the printer or the driver. However, the common theme was that it was only Quark and not earlier versions.the CUPS filter solution is no helpIn QuarkXPress, you can choose a data format to specify how the data for the pictures in your layout are sent to a PostScript printer: Binary, ASCII, or Clean 8-bit. Because binary data may be incorrectly interpreted through certain network printing protocols, or because your specific PostScript printer may not be able to interpret Binary data, you may need to change the data encoding method from Binary to either ASCII or Clean 8-bit. Please see the More Information section of this article for a detailed discussion of how these encoding methods differ.
Solution: Go to File > Print and select the Pictures pane. In the Data field of the Pictures pane, select either ASCII or Clean 8-bit.
I was told by HP that I could not use USB over a network. I Called Apple support and was hooked up through my Airport Extreme using USB. You want a better solution invest in a Mac. They have the know how and what they are doing. It's like comparing a Model T to a Cadillac when you tout PC's.
At this point you are much better off installing a USB wireless antennae than spending money on an Airport card, cracking open the iMac, and installing it.
USB wireless adapters are cheap, plentiful, and have more capabilities than the generation of Airport cards that were made for G5 iMacs.
well imac G4's don't have built in airport (wireless internet) included as usual with apple its another item you must buy an airport extreme card then hook it up to an airport base station another item to buy via wireless internet then hook you airport extreme base station up to your modem via ethernet. whew ok now sync the airport base station to your imac using airport set up application then select your network and type your WEP password and viol internet in about 1 hour if your lucky hope this helped my fingers hurt now LOL.
