I am receiving an error of SC 481. The Ricoh folks would give no info without a large repair fee up front. Therefore, I have a big paperweight. Thanks.
Printcopy.infohttps://printcopy.info > code=SC401
Code: SC401 · Description: Transfer positive electrode current error A transfer roller current leak signal is detected. · Causes: • High voltage supply board set ...
Code: SC401 · Description: Transfer roller open error · Causes: • Transfer power pack defective • Poor connection between the transfer current terminal and the ...
Noise aside, the most common cause of 202 codes on those things is the front door is not closed on the left hand side. It activates the laser shutter.
Mar 10, 2018
PrintCopy .infohttps://printcopy.info > code=SC390
Code: SC390; Description: TD sensor error 1. The TD sensor outputs less than 0.5V, 20 s after the TD sensor initial setting has been performed.
Missing: cod ' Must include: cod
Fixyahttps://www.fixya.com > ... > Ricoh
The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that ...
Copytechnethttps://www.copytechnet.com > 56632-sc-390-a
Sep 24, 2011 - I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed ...
PrintCopy .infohttps://printcopy.info > brand=Ricoh Description: Color development motor error When the motor speed is within the target level, the motor sends a lock signal (High to Low at CN214-5) to the BCU.
Missing: c7100sx ' Must include: c7100sx
Code: SC381 ; Description: Charge potential abnormal - Definition - [D] When performing the process control self-check, the charge potential of the drum is not ...
