Hello there:
There are several hoses that run under the washing machine that go to different pumps that could be getting loose from the machine operation over time
so and alos hoses are subject to failure due to wear and tear
So what you are going to have to do is to remove the front lower panel and use a flashlite and look to see where the leak is coming from
and then once yo have found where the leak is coming from you may be able to tighten the hose clamp if it is that is leaking and hopefully not he hose itself. and if it is the hose it'self that is leaking have to replace the hose ok
Hope this is very helpful for you
I have replaced what's called the drain bellow about three times - it's an accordian-looking rubber tube about 2" in diameter or so that fails about every year or year and a half. I swear there's a class action suit there. It has only a few connection points so easy to replace. I can't remember which way you're supposed to NOT turn the unit over - check the owner's book or talk to a service rep.
