Televison & Video Logo
Posted on Oct 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Video lag issue when playing pc games on my wd-65737 using a dvi to hdmi cable to connect it.
Chi Chu
Level 3:
  • Televison & ... Master 8,457 Answers
  • Posted on Oct 22, 2009
Chi Chu
Level 3:
Answers
8457
Questions
0
Helped
2823126
Points
26282
Check ur game program,if not the game program than it ur main video backlight board is dying.
2helpful
2answers
How can i connect my hp pavillion s5610y to my bravia tv
This is a bit complicated since there is no HDMI output capability to the PC, only VGA and DVI. First, check to see if the Bravia has one of its HDMI ports listed as DVI capable. If it does, it should have accompanying audio jacks (red/white) for it. What you would need to get is two different cables for interface. The first is a DVI-to HDMI cable to run from the PC DVI port to the Bravia DVI-compatible HDMI port. You cannot run the DVI to a regular HDMI port because if you do you will get only picture and no sound. DVI outputs, unlike HDMI outputs, do not carry the audio signal. A DVI-compatible HDMI port on a TV set will connect the video from the HDMI port and the audio from the reserved audio port accompanying it. The second cable you need will be a mini stereo audio plug to RCA jacks. This will connect between the PC audio out (green), and the DVI audio plugs on the set. See pictures for cables below
Once you have this done, selecting the appropriate HDMI port on the set should result in audio and video getting to the unit. If you only need the video (you are going to use the PC speakers), then you don't need the audio cable and you can use any HDMI port, but you cannot control the volume using the TV set remote. You would need to use the PC volume settings. (Just as an afterthought if the set has no DVI-compatible HDMI port).
2answers
Can't get any sound when playing discs through a blu ray player connected via a hdmi cable and DVI adapter.
The DVI adapter stops the audio. Use the audio out ports on the bluray player to connect an audio pair cable to the tv.
Connect aspire v5-552p to tv
It depends on the ports the computer and the TV have
If both have VGA (blue) use a VGA to VGA cable.
You can also use an S-Video-to-S-Video cable
If both have DVI, use a DVI-toDVI cable.
If both have HDMI use an HDMI-to-HDMI cable.
Other possibilities are combinations of the various modes above VGA-to-DVI, VGA-to-HDMI, VGA-to-S-Video, etc.
VGA-To-D
Just got an xbox 360 slim 250GB but when I went to play halo 3, the game was lagging along with the xbox menu itself. I even connected a plug-in controller and I had the same result showing that it was not...
If you just bought it brand new, then return it for an exchange. Its not wise to keep an electronics appliance or game console that is having issues straight out of the box. Using your A\V (RCA) cables instead of an HDMI cable shouldn't be causing any lag, at least nothing that is significant enough to notice.
Im trying to use my TV as my monitor for my pc?
What problem are you having? The connection should be fairly straight forward depending on your computer's video out. You can use a VGA cable, DVI to HDMI (check your graphics card manual for single link or dual link on the DVI side), or component video (even S-video). If you have HDMI out on the video card, use an HDMI cable. If you want to connect to the TV's speakers, you need at least an 3.5 mm audio cable (or 3.5 mm to RCA audio).
The DVI cable can be either a DVI to HDMI cable or DVI to DVI or HDMI to HDMI with a DVI to HDMI adapter at one or the other end.
I hope this helps.
(you will need to go through the input modes to find the signal. Some TVs need to be on (with no signal) before the computer is turned on.)
1helpful
How can I connect Panasonic TH-37PX60U Flat panel plasma tv to my computer?
It will depend on your video output options on the computer. If you have HDMI output, just use an HDMI cable and an audio cable (this will need to be a 3.5 mm to RCA audio cable). If you have a DVI output, use a DVI to HDMI cable and the audio cable (or a DVI to HDMI adapter and either a DVI or HDMI cable depending on which side you want to put the adapter). If you only have VGA out from the computer, use a VGA to DVI adapter and the DVI to HDMI connection and the audio connection. (Theoretically this should work but each adapter will have some signal loss issues.)
Some graphics cards have a video output, S-video or Component video, which would also connect to your TV with the audio cable. (Read your cards manual for more information)
I hope this helps.
(For DVI to HDMI cables, you will need to check if you have a single link or dual link DVI output. The wrong cable may not work.)
Cannot play video games downloaded
I was getting the same problem with my lcd tv. I was using a DVI to hdmi cable to connect the pc to the tv. I switched to a vga cable and I was able to finally get into the game. Once you get into the game make sure you change all the video settings to be compatible with your tv i.e. resolution for a 720p set should be 1366x768 on the game resolution, and you should also change the refresh rate to 60hz in the game if that is the max. on your tv.
Once you do this, you can then put your hdmi cable back in and get into the game. Every game I install I have to first run using the vga cable, and then switch to HDMI.
Play station 3 hdmi-dvi
Yes you can. It will not be like a HDMI cable but it will be better than the RCA. Your image will be in your HDTV (1920 × 1080). But you will have to buy a HDMI cable and and HDMI-DVI adaptor. You will not have sound so you will have to connect either your RCA or if you have a Digital Optical Audio sounds better.
If you have any questions just ask.
2answers
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
11helpful
4answers
Time lag between Playstation 3 and LCD TV.
SOURCE: http://boardsus.playstation.com/playstation/board/message?board.id=confrontation&thread.id=735278&view=by_date_ascending&page=2
If your playing with lag on your new HD LCD your at a competitive disadvantage! Everything you see happens seconds later than your opponent who has his/her settings right.
The fix:
1. Connect your PS3 using HDMI Input 2.
2. SELECT or RENAME the HDMI Input to PC. Already pointed out, but this does not make the majority of tv's run in PC mode.
3. On the PS3 start-up menu go to Settings---> Display ---->
Choose HDMI ----> DO NOT choose AUTOMATIC ----> SELECT CUSTOM ----->
4. Now, Select all the Resolution options EXCEPT 720p. This will force your games into 1080p mode. What it will also do is drop any game that doesn't have 1080i/p support into 480. Games like Burnout Paradise, Vegas 2, Heavenly Sword, NHL 08 and more will be dropped into SD (480) rather than HD. Your picture will be terrible. 720p is standard gaming resolution currently, 1080i/p is not.
5. Save and complete the display setup.
6. Turn off the PS3. Turn off the TV.
7. Turn on the TV. Turn on the PS3.
8. Complete! (Lag eliminated). Please spread this around!
*The key to eliminating ALL LAG is modern LCD's need to be in PC MODE (NOT GAME MODE) On many tv's, PC mode requires you to use a VGA or DVI connector. You'll either need to buy an HDMI adapter or an HDMI to VGA / DVI cable if that's the case.
and the Source MUST BE IN 1080p so that the TV can use it's NATIVE RESOLUTION.* Please, check your tv's native resolution. If you have a plasma that only does 720p, your native resolution is probably 720p. You do not need to follow these steps, it will only make things worse. If your tv's native resolution is 720p, obviously you want to keep your display settings at 720p on your PS3. If your native resolution is 1080i, you shouldn't go selecting 1080p. If your native resolution is 1080p on your TV, you need to be aware that removing 720p as an option will force many games into 480.
Keep these things in mind and remember that the steps above are far from a cure all solution. .
Lag gone! Worked for me! (SAMSUNG LNA52850)
Source : http://answers.yahoo.com/question/index?qid=20081225141902AApX7cJ
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
