Adjusting Display Brightness
You can use the following procedures to adjust display brightness to make it easier to
read under different lighting conditions.
Press the "Fn" key and then press the "5" key or "6" key after con? rming that "F"
is displayed in the lower right corner of the screen. Pressing the "5" key adjusts
brightness for a darker display, while pressing the "6" key adjusts brightness for a
lighter display.
In order to continue to make adjustments, press the "5" key or "6" key again after
? rst pressing the "Fn" key.
Brightness settings can also be made by navigating to the menus and tab in order of
Start ? Settings ? System ? Backlight.
The manual is here:
Casio IT 800 Series User Manual
But it's not manually adjusted; there's no adjustment knob for vertical nor horizontal adjustment..we checked and it doesn't have a manual adjustment and i believe the adjustment needs to be done through the remote control so basically, i think what we need is a code to adjust it; that's what we need help on now..
