Words (and possibly picture) are blurry, as in they extend out to the right from where they should...
(More)
Words (and possibly picture) are blurry, as in they extend out to the right from where they should be crisp and short. Adjusted all settings, nothing changed. It's particularly bad when viewing the guide on my cable.
set will not receive hd channels on cable, but will receive one close station on antenna. another...
(More)
SET WILL NOT RECEIVE HD CHANNELS ON CABLE, BUT WILL RECEIVE ONE CLOSE STATION ON ANTENNA. ANOTHER HDTV HOOKED TO MY CABLE RECEIVES ALL THE HD CHANNELS.
I'm trying to get a service agreement for several Samsung HD LCD TVs, NEC projectors and one video...
(More)
I'm trying to get a service agreement for several Samsung HD LCD TVs, NEC projectors and one video camera in our training center. What are the three most common repairs problems with each equipment and the repair costs? VT85LP VT50LP VT60LP VT75LPE
Samsung lcd 360 32'' on what level shall I set the video noise reduction for the clearest picture...
(More)
Samsung lcd 360 32'' on what level shall I set the video noise reduction for the clearest picture /watching still analog tv /
Lower 1/4 of dislpays resolutions lines(every other ne) are black and fade into the piceure in th...
(More)
Lower 1/4 of dislpays resolutions lines(every other ne) are black and fade into the piceure in th lower right corner. LCD LNT4671FX/AXX
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
