I have a sony KDL-32S2010 that the standby light flashes red three times. What will it take to...
(More)
I have a sony KDL-32S2010 that the standby light flashes red three times. What will it take to repair it? This was the result of a lighting strike.
it's Sony Bravia KDL-40W. I can turn on and turn off the TV. But I got only black screen with...
(More)
it's Sony Bravia KDL-40W. I can turn on and turn off the TV. But I got only black screen with channal 0 on. I cannot change any settings or channals on remote or from the buttons on the TV.
I'm only getting black and white when playing a DVD on my Sony Bravia? Is there toggle switch for...
(More)
I'm only getting black and white when playing a DVD on my Sony Bravia? Is there toggle switch for color/black and white? The DVD player and sound system are Samsung.
I have sony Bravia which received all channels well till chan7two was started. From next day no...
(More)
I have sony Bravia which received all channels well till chan7two was started. From next day no reception of chan 7 on any frquency. I live in liverpool sydney. In digital tv receiver is it possible to receive all channels but one due to tv circuit fault.
Sony bravia lcd KDL40V3000, when switched on, picture comes for 1secs, later the red led bliks, this...
(More)
Sony bravia lcd KDL40V3000, when switched on, picture comes for 1secs, later the red led bliks, this pattern repeats continuously, Have you any Idea what problem is?
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
