Hello Acerilli
Sounds like the print head is either blocked or defective.
Try cleaning the print head first to see if this clears up the lack of black ink.
Press the "menu" button and then scroll down to the "ink" option and press OK
Now scroll down to "cleaning" and select OK.
Select "Black" and press OK then Black Start.
Repeat this process up to a maximum of 5 times.
If this does not clear it up, try a "purge".
Press "menu" "black start" "0 7 6" in sequence as quickly as possible (within 5 seconds)
All the lights should flash and you will see "cleaning_all" on the screen.
Now press 3 and Black start.
If this still does not work and there is no black, the print head is defective and needs to be replaced.
If you are under warranty, you can check here for a service center.
http://www.brother.ca/en/customer_care/service_centers.asp
If there is no service center in your area and you are under warranty, call brother for an exchange.
