20 Most Recent Brother MFC-8840D All-In-One Laser Printer Questions & Answers
you have a battery operated all in one laser printer?
Brother... | Answered on Feb 18, 2016
I looked that error "6D" and could not find anything.
Although there is a error 6E that denotes a hardware problem with the machine.
Brother... | Answered on Mar 27, 2014
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Thankyou,
Brother... | Answered on Mar 01, 2014
Sir/Madam
I Think There is paper jammed in the printer.
Action:
Press button A, open the front cover and remove the jammed media.Make sure that there is no paper jammed in the paper trays.
Or Still Having Brother Printer Problem The Follow Us For On: Brother Printer Support
Brother... | Answered on Jan 23, 2014
Check on TOP of the bottom paper tray.
The NO paper sensor is "hanging" to sense no paper condition.
Free this sensor (it may got stuck or defective)
Brother... | Answered on Jan 18, 2014
change paper pick-up roller & paper stop roller in ADF
Brother... | Answered on Jan 08, 2014
The scanner needs to be reset. Turn off the device and then turn it on again.
Please note that when you turn off the MFC's power switch its memory will be cleared. To check whether the MFC has faxes in its memory, click here.
Brother... | Answered on Nov 27, 2013
The beep noise three times indicates taht there is an error or one of the buttons are stuck.
Please turn off the Brother and press down on each button.
Brother... | Answered on May 16, 2013
most likely you have a bad drum. it can also be the fuser.
what is the distance between the first word and the duplicate that follows it.
Brother... | Answered on Mar 08, 2013
MP means multipurpose tray.or tray 1.open the tray,blow air in,could be small piece of paper stuck inside.
Brother... | Answered on Feb 12, 2013
The only way to clear the toner low i believe is to change the toner.
Brother... | Answered on Oct 04, 2012
Look at back of machine and at your new hinge, note the screw hole, if you undo both of those on the back of the printer, entire doc feed will come up and out, BECAREFULL just lift A LITTLE is enough to enable hinge base to be free of sockets (many cables attached) and place doc unit slightly sideways on copy glass to enable yourself access to 3 screws that hold hinge.
Brother... | Answered on Aug 03, 2012
Brother MFC-8840D All-In-One Laser Printer Logo
161 questions posted
James Cagle
James Cagle
Jim Keysor
ctnozil
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
jammed piece
  • Office Equipment & Supplies
