Washing Machines Logo
Donna Rawson Posted on Feb 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E21 error code came on my Hoover washer when putting in any programme
Julie Johnson
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 25, 2020
Julie Johnson
Contributor
Level 1:
Answers
Questions
0
Helped
8561
Points
Ive had hoover tumble dryer for 2 days from new when I got the E21 fault manufacturer exchanged for another brand new appliance and 2 days later I have the E21 fault with the new appliance what's going on?
brian williams
Level 3:
Genius:
  • Master 1,980 Answers
  • Posted on Sep 19, 2019
brian williams
Master
Level 3:
Genius:
Answers
1980
Questions
9
Helped
741899
Points
5402
I only find e21 error for hoover washers...
5 Related Answers
Anonymous
  • 210 Answers
  • Posted on Jun 03, 2008
SOURCE: E21 error while on final spin
E21 is telling you that it has not drained the water out. You may have something stuck in your drain pump.
Sgt 48
Anonymous
  • 240 Answers
  • Posted on Mar 16, 2009
SOURCE: wont spin
check drain pump for obstruction, (access from rear panel) pull hose boot from tub and ck basket in hose. read tech sheet for code definition while your there. have plenty of towels and wet vac ready
mohanchennai
Mohan Sriraman
  • 490 Answers
  • Posted on Oct 18, 2009
SOURCE: Canon DR-5020 Error Code E21
Just saw your problem! 'E21' refers to Document Board Motor Problem' Check if there is any loose contact and if required replace motor.
S. Mohan, Chennai, India
richroth
Richard Roth
  • 9472 Answers
  • Posted on Nov 26, 2010
SOURCE: Kenmore washer model number 417.44082400
If the control detects that the washer still has water in it even though it is apparently dry, the control will continue to run the drain pump and will not go into the spin model. If the tub is completely dry, you could have a problem with the water level pressure switch or the control board. This would normally cause an E21 error code on the washer. I provided the technical information for this washer in the image below. The washer will normally signal an error code with a series of blinking lights on the console when the washer will not go into the spin mode. I recommend that you continue to allow the drain pump to run for a while and see if an error code will appear. This will normally indicate the likely failed component that is causing this problem. The information below is intended for technicians. Follow electrical safety guidelines if you use this information. Unplug the washer to disconnect electrical power before accessing internal components. Some of the checks below call for live voltage checks. I do not recommend that you conduct this type of test on the washer. Live voltage checks should only be conducted by a service technician.
Anonymous
  • 3301 Answers
  • Posted on Jul 01, 2011
SOURCE: My washer appears to be
heres a breakdown on how to do that http://www.washingmachineerrorcodes.com/?p=81
My washing machine has a code e21 what do that mean
Please read description carefully about error code
Logik Washing Machine Error 21: "E21"
Error Code Definition: Washer has not drained in allotted / time washer not draining.
How To Clear Error Code:
-Check that filter is not blocked or kinked
-Check drain hose is clear of any blockage or kinked
-Check wires to drain pump
-Check drain pump is not faulty
-Check level sensor and switch
-Check wires to level sensor
here is link for more about your all error code which will may helpful in future, LOGIK Washing Machine Error Codes How To Clear
here is video which helpful regarding solve and understanding error.
1helpful
2answers
Error code e21 on frigidaire affinity washer cleaned pumped and ran a rinse cycle it did fine put clothes in to wash it ran for 10 min. then stopped.
Hello Deena,
Error Code e21
means the water is not pumping out fast enough.The most likely reason is because the washer drain filter is clogged.
Here is a solution:
  1. Pull the machine out from the wall.
  2. Then take the panel out in the rear. Once the panel is off you will see the drain pump.
  3. Disconnect the drain Tube between the Tub and the Pump.
  4. Look inside the pipe you will find the Drain Filter.
  5. Clean the filter out ( you will be surprised of "things" found in the filter) then put the machine back together
  6. Try a full cycle.
That should end your problem.
Best of Luck!
JP
1helpful
2answers
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Front load washer e21
Good Morning Friend,
I see that you are receiving an E21 on your Frigidaire washer, model# ATF6000ES. The E21 error code states that water is not pumping out fast enough. Here are a couple of suggestions that you can try.
    1)Check the drain hose for any kinks or clogs. Also, make sure that the drain hose is only 6-8 inches down in the drain pipe. If the drain hose gets backed up with water this error can occur.
    2)Make sure that the actual drain pipe, where the drain hose goes into, is only a maximum height of 8 feet. If it is longer than 8 feet, you will need to cut some of the pipe off.
    3)Make sure that your homes drain pipes are not clogged. If they are, you will need to unclog them. Call a plumber if necessary.
    After checking the above suggestions, reset your washer by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. If you are still receiving an E21 error code, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why you are receiving an E21 on your appliance. Hope this is helpful.
    -Best regards-
    WP
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
My frigidaire washer has e21 error code and wont start
Hello - The error code "E21" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
1helpful
Hoover washer dryer Error Code E12 during dry programme. How can I fix?
E12 means a problem filling on dry cycle.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
2helpful
2answers
Error code E21
E21 Water not pumping out fast enough. .
Check for Restriction in drain pump or hose...
No restriction. Go to step (2).
2. Start the washer and check for 120 VAC at the
drain pump. if no voltage Replace the control board.
120 VAC. Remove the pump and check for
blockage. If blocked, remove the restriction,
if not, replace the pump.
3helpful
E21 error code
There is a E21. Water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys.
PLEASE RATE THIS !
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
