SOURCE: Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
SOURCE: Hoover Tumble Dryer trips out
Hi
Thanks for using FixYa. It
seems to be the issue with the Thermal Fuse going bad and needs to be replaced.
It is mounted to the exhaust duct inside the
back cover panel. Whenever this fuse goes bad it'll either trip the circuit breaker or the dryer wont heat. You can also check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please
do rate the solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
Testimonial: "Thanks for your quick response I will try and work out whch one it is and replace it"
SOURCE: Hoover washer/dryer VHW854D SHOWS ERROR
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
