20 Most Recent Hoover VHC391 T-80 Dryer Questions & Answers
I keep getting E15 Error code on my Hoover Tumble dryer flashing. The dryer is working, but heat is cold.
Control board fault. See... https://www.espares.co.uk/advice/careandmaintenance/how-to-fix-an-e15-error-on-a-hoover-washing-machine
9/25/2020 11:26:48 AM • Hoover VHC391... • Answered on Sep 25, 2020
0answers
2answers
OK so the tumble dryer stopped working. I press
Sounds like you need a motor. Buzzzzzzz click stop. Push on it a little and it starts motor is going. I’m happy to help further over the phone at https://www.6ya.com/expert/william_e43a8a4d83a5f604
3/1/2015 2:58:21 AM • Hoover VHC391... • Answered on Mar 01, 2015
Why doesn't it spin?
Could be few reason such as no power chck out house breaker or fuses ,broken parts,defective door switch or defective componants ,Need multimiter and knowledge of electricity
1/13/2015 2:57:20 PM • Hoover VHC391... • Answered on Jan 13, 2015
Replacing heating element
must be more specific
9/1/2014 1:17:40 AM • Hoover VHC391... • Answered on Sep 01, 2014
Have a 6kg hoover tumble dryer making noises when on sounds like something trappped under drum
it sounds like your bearing are gone you can buy a bearing kit its not an easy job but if your a handy man or woman it can be done
7/29/2014 5:37:59 PM • Hoover VHC391... • Answered on Jul 29, 2014
Seems to leak and not getting things really dry
is it a condenser dryer if so check your pump it might be faulty
4/9/2014 7:43:56 PM • Hoover VHC391... • Answered on Apr 09, 2014
0answers
0answers
My hoover tumbledryer condenser vhc381 wont work
Fixed: dryer not heating up (Hoover vision hd 381) Just fixed a hoover vision hd 381 tumble dryer. Thanks to the help on this site and others. Thought I would share my experience here. Problem was tumbledryer not getting hot. Traced it fairly quickly to a blown heating element. Took the back heater cover off (bulging silver panel), unscrewed heater, peered inside and it was somewhat charred (tested the thermostats which were fine). Dryer works now. The really tricky thing was unplugging the heating element to replace it. The plugs are located inside the main housing. However, the advice found on much of the internet to how to do this is incorrect. In particular the advice to remove the drum is not correct. The way you access the plugs is by pulling the main heating wire through the hole in the unit, and feeding the plugs through one by one. Then you can simply unplug the old one, plug in the new one. Two things are necessary for this: i) Remove the rubber collar keeping the main wire secure in the hole into the main unit. ii) Pushing the plastic grommet through the small hole in the main unit. This grommet immobilises the main wire - you won't feed it through without it being released. You'll see quickly what this looks like on the replacement heater you should already have. The white plastic grommet protrudes a little out of the back of the unit close to where the heating wire enters the unit. Pinch it with a pair of pliers and push it back into the unit. The wire will then be free to pull through, and one plug at a time will fit through till you have all four. Then just pull the plugs off (pushing the new ones on requires quite alot of force). In fact it is not necessary to strip down the unit at all to do this, apart from one thing: putting the grommet back for the new heater. It needs to be pushed from the inside. This probably isn't strictly necessary (I say probably), but I did it anyway. I suspect the grommet is there so that if the heater hangs free, it doesn't pull the wire up and stress the plugs. But I wanted to put the thing back exactly like I found it. However, you still don't need to take the drum out to do this. You do however need to take the plastic mounting off that supports the drum. Then you can reach in with your hand and manouver the grommet into place. So the repair ideally should be firstly to replace the heater in the way described above. Then put the cover back on as you'll need the unit on its back later. Briefly, instructions for stripping down the unit: i) Unscrew the 3 top screws located on the back of the unit holding the top of the unit on. Slide the top back and lift it off. ii) Disconnect the door by undoing the allen key screws. Once these are off, lift the door off. iii) Unscrew the plastic faceplate from the top (2 screws), to reveal two of 8 screws holding the metal front in place. I wired the plastic faceplate (with control knobs) onto the unit so I could still access these 2 screws, without the faceplate hanging free and risking disconnecting something. iv) Unscrew the remaining 6 screws (4 near the rubber seal, 2 at the very bottom). Remove the rubber seal carefully. v) Lift the metal front off, and disconnect the wires (keep track of which goes where!) Place the machine on its back (support it with blocks where the bulging heating element is). vi) Unscrew the four nuts holding the plastic mounting which supports the drum. vii) Slide the plastic mounting up by about 10mm and hinge it out from the bottom. This lifts the felt seal off the drum. The machine needs to be on its back so the drum which is now only held on to the back plate doesn't stress itself under its own weight. Make sure you know where the wires need to be fed. I took videos and pictures on my phone at each step. viii) It should now be possible to reach in past the drum and click the grommet back in place. cheers Mat ([email protected] if anyone wants to ask questions).
1/25/2014 3:49:21 PM • Hoover VHC391... • Answered on Jan 25, 2014
Lint is trapped behind door between door and seal and impossible to clear. Any suggestions?
I just stripped down my hoover vision hd 381 model. Its not too bad, and you can get all sorts of lint out. Here's the long version of my post on another site. Your model may be similar to mine: Fixed: dryer not heating up (Hoover vision hd 381) Just fixed a hoover vision hd 381 tumble dryer. Thanks to the help on this site and others. Thought I would share my experience here. Problem was tumbledryer not getting hot. Traced it fairly quickly to a blown heating element. Took the back heater cover off (bulging silver panel), unscrewed heater, peered inside and it was somewhat charred (tested the thermostats which were fine). Dryer works now. The really tricky thing was unplugging the heating element to replace it. The plugs are located inside the main housing. However, the advice found on much of the internet to how to do this is incorrect. In particular the advice to remove the drum is not correct. The way you access the plugs is by pulling the main heating wire through the hole in the unit, and feeding the plugs through one by one. Then you can simply unplug the old one, plug in the new one. Two things are necessary for this: i) Remove the rubber collar keeping the main wire secure in the hole into the main unit. ii) Pushing the plastic grommet through the small hole in the main unit. This grommet immobilises the main wire - you won't feed it through without it being released. You'll see quickly what this looks like on the replacement heater you should already have. The white plastic grommet protrudes a little out of the back of the unit close to where the heating wire enters the unit. Pinch it with a pair of pliers and push it back into the unit. The wire will then be free to pull through, and one plug at a time will fit through till you have all four. Then just pull the plugs off (pushing the new ones on requires quite alot of force). In fact it is not necessary to strip down the unit at all to do this, apart from one thing: putting the grommet back for the new heater. It needs to be pushed from the inside. This probably isn't strictly necessary (I say probably), but I did it anyway. I suspect the grommet is there so that if the heater hangs free, it doesn't pull the wire up and stress the plugs. But I wanted to put the thing back exactly like I found it. However, you still don't need to take the drum out to do this. You do however need to take the plastic mounting off that supports the drum. Then you can reach in with your hand and manouver the grommet into place. So the repair ideally should be firstly to replace the heater in the way described above. Then put the cover back on as you'll need the unit on its back later. Briefly, instructions for stripping down the unit: i) Unscrew the 3 top screws located on the back of the unit holding the top of the unit on. Slide the top back and lift it off. ii) Disconnect the door by undoing the allen key screws. Once these are off, lift the door off. iii) Unscrew the plastic faceplate from the top (2 screws), to reveal two of 8 screws holding the metal front in place. I wired the plastic faceplate (with control knobs) onto the unit so I could still access these 2 screws, without the faceplate hanging free and risking disconnecting something. iv) Unscrew the remaining 6 screws (4 near the rubber seal, 2 at the very bottom). Remove the rubber seal carefully. v) Lift the metal front off, and disconnect the wires (keep track of which goes where!) Place the machine on its back (support it with blocks where the bulging heating element is). vi) Unscrew the four nuts holding the plastic mounting which supports the drum. vii) Slide the plastic mounting up by about 10mm and hinge it out from the bottom. This lifts the felt seal off the drum. The machine needs to be on its back so the drum which is now only held on to the back plate doesn't stress itself under its own weight. Make sure you know where the wires need to be fed. I took videos and pictures on my phone at each step. viii) It should now be possible to reach in past the drum and click the grommet back in place. cheers Mat ([email protected] if anyone wants to ask questions).
1/25/2014 3:28:39 PM • Hoover VHC391... • Answered on Jan 25, 2014
Takes too long to dry
Is it heating up at all? I just fixed my vision hd hoover 381 dryer by replacing the heating element. Email me if you think this might be you ([email protected]). When the dryer is running, feel the metal heater housing (carefully) on the back (silver bulge) if your model is like mine.
1/25/2014 3:27:03 PM • Hoover VHC391... • Answered on Jan 25, 2014
Can u help me
follow this steps and fix it, use the multimeter . Merry Christmas 1. No power to the dryer Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced. 2. Heating element A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective. 3. Thermal fuse Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting. f03685a6-67e6-44f4-9575-d4d78a3f14ab.gif
12/18/2013 12:49:54 PM • Hoover VHC391... • Answered on Dec 18, 2013
Hoover vhc180
Sounds like an overheat sensor is tripping. Remove the exhaust duct from the dryer and see if it stays heating. If it does you have a clogged vent.If it still acts up you have an internal blockage or a weak sensor and the dryer will have to be taken apart to service it.
11/5/2013 3:38:16 PM • Hoover VHC391... • Answered on Nov 05, 2013
Hoover VHC391 T-80 Dryer Logo
68 questions posted
Top Hoover Dryers Experts
Marvin
Marvin
Paul Carew
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
View Most Popular
Hoover Dryers
  • Hoover Dryers
Most Popular Question
seems leak not getting things really dry
  • Dryers
