SOURCE: rattling noise by drain pump,
Follow this link for service manual.
This will explain it all
SERVICE MANUAL
SOURCE: removal of door seal on hotpoint washer drier wd420
You will achieve nothing by removing the door seal .
Depending what is in there, better to leave alone and trust it will find its way into the filter.
If it is anything substantial then it involves major work.
SOURCE: printer unable to clean therefore will not print "clean unable 46
"unable to clean".
absorber full or mechanical problem.
first try to reset absorber counters.
SOURCE: When we run the wash, black marks appear on some
I had the same problem - mostly it was noticeable on whites. I have a well and hard water. When I removed the dispenser - I found a nasty, brownish buildup which seemed to flow down with the bleach and attach to my clothes. When I cleaned the dispenser and the surrounding area - my whites came out white! Sometimes even gray haired women can do mechanical things.
SOURCE: Child has inserted foreign object into PS3 machine
look at the left hand side of yor ps3 at the top you will see a small sticker that says something about the warranty and removing it will void so on and so on peel this sticker off and you will see a screw (you will need a set of security screwdrivers the 6 point phillips is the one you need) once you have that out the top of the ps3 should slide sideways and come off then you will c more screws and the rest you can pretty much figure out yourself, get back to me if you hav any trouble
