It is apparently to add extra water for larger items in the washer.
https://www.mumsnet.com/Talk/housekeeping/1099503-whats-the-aqua-plus-for-on-my-bosch
SOURCE: bosh washing machine won't do any programmes
If it fills then the next phase is to agitate.
To do that the motor must drive
Can you hear a whirring sound from the machine if you get close to it if so then the belt driving driving drum may have snapped.
If not then the motor brushes may have stuck or have worn out.
Does the machine programmer advance by itself or are you turning the dial
SOURCE: My Bosch washing machine is displaying a key and -0- sign and is not starting any cycle please help
Sounds like the pump and filter are blocked
SOURCE: my Bosh washing machine has excessive vibration.
it may be level but if the feet are not adjusted to be tight to the floor this will cause it to walk so try adjusting the feet then lock the locking nut I am sure you will find 2 that are not adjusted tight enough.
SOURCE: my bosh washing machine not washing.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
SOURCE: where I can find the service manuals for Whirlpool
You will need to type into your search engine 'whirlpool washer manual' and you should be presented with a number of sources from which you can either download a manual for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
