SOURCE: ILO LCD TV
It sounds like you have the problem many of us have faced and I am not aware of anyone actually getting one of these things fixed. suggest you P)USH real hard, ANY WAY YOU CAN for an exchange. there are two parts to the control circuits in these tvs [ilo] one part deals with the on/off and the other, much more complicated and I think not well engineered, deals with all other aspects of control- including vol, chan changing, SIGNAL SOURCE SELECTION, and on and on. If you can get it fixed- me-thinks it'll be a first. .....pull EVERY trick in the book to get an exchange.
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
SOURCE: source in samsung 42 lcd keeps changing
it has something to do with the key pad assembly, i guess the source button may be sticking in. Has the key pad board been disconnected?
SOURCE: I need to change the source on my tv to HDMI without my remote
Not sure if yours is the same but Philips codes work with Skyworth and if you hit the TV/AV button on the side of the TV and the table of options should come up. And then with the channel +or- go up and down till you are on HDM1 or where ever you want and then touch the TV/AV again when you are there.
