Venturer KLV39150 15" Under Cabinet LCD TV with Built-In DVD Player & Radio Logo
Question about Venturer KLV39150 15" Under Cabinet LCD TV with Built-In DVD Player & Radio
How to source AV Input on remote - Venturer KLV39150 15" Under Cabinet LCD TV with Built-In DVD Player & Radio
Posted by allan p currie on
  • Amy Hartman
    Amy Hartman Aug 13, 2018
    On am HCI tv if you turn the tv off and then press and hold the power button in the input will auomatically change to whatever you have plugged into the hdmi port, PlayStation, DVD player.. etc...
Claude Kayser
    Top Expert:
  • 9,098 Answers
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Posted on Feb 08, 2016
Where is the AV button on the remote control for a Tevion vision 2368 portable dvd player
Look for the source / input button on the remote to change the AV input.
AWA Tv wont allow the AV source to load. constantly says no signal.
Scan through the AV input source selections on the remote until you find the right input
2answers
How do I select AV input
Older tv sets tend to have at least one button on the remote to select the AV input but more modern sets the function is automatic - switching to AV when a signal is received via the scart socket, etc.
A dialogue box on the insignia tv screen says no signal. Press input button on remote control. Then select the device you want to view. Be sure device is on.
what the message is telling you is to select the input source to use AV channel selection ( AV 1--AV 2--AV 3 etc )
antenna - dvd player , gaming console etc
2answers
How can I change to av/ext channel
input source button usually on remote control device.
Where do i find thr AV setting on my tv set?
If you mean changing the input source to AV, it depends on the brand and model. Some units have an Input or Source button on the front panel (or side panel) of the TV and on the original remote. Other models only have this button on the remote.
If you are interested in a replacement remote for a unit that only has the Input button on the remote, try a searching for the model on remotes.com . Alternatively, look for a universal remote that is newer than the TV with an Input or Source button. Then try all the codes for the brand until you find the one that makes all of the features of the remote work.
If you are interested in the signal information (resolution, for example) of the content on the AV source, try the Info button on the remote (if available). To adjust the setting enter the Menu (either from the button on the remote or the TV panel (if available) and look for the Picture submenu.
I hope this helps. If you provide the make and model of the TV, I may be able to provide more information.
Trying to get to av input on tv and i dont have
Do you have a physical source button on the TV or try going through your menus to see where to switch input sources. I'm sure you can do this with the buttons that are on the Bezel of the TV.
Blessings,
A/V Media Guy
I have just purchased a home cinema system: SONY 46" LCD, KEF3005 SPKS, SONY STRDA2400ES RCVR, SONY S55O BLURAY. ALSO A VIRGIN HD+ BOX. CAN YOU ADVISE BEST WAY TO CONNECT THIS ALL TOGETHER FOR BEST...
connect all source devices to the Sony LCD tv inputs. and connect the audio output from the tv to the aux input or any one input of the audio reciever. This way you can just leave the av reciever on and control all the input switching with te tv remote. Avoid connecting all the av sources to the reciever and the tv as a monitor from the video out of the av reciever. Just use the av reciever to reproduce the desired audio and do all the input switching with the tv remote. This will simplify the operation an lessen the chance of someone changing the audio settings of the av reciever.
Cannot view / record from AV input - no option on remote
look for a source button or 1 with a square with an arrow pointing in to it both are types of av button
How do u turn to scart channel without a remote
Not knowing what model of TV you have, the most common ways are either by using the Source button then scroll to AV1 input or if you have a Menu button there may be a sub-menu for Input, again select AV1 (depending on which AV connector you are linked you maight have to select AV2). If you have a DVD or VCR connected to the AV source, then when pressing play the DVD/Tape should automatically switch over to AV.
Top Venturer Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Venturer Car Audio and Video Expert? Answer questions, earn points and help others
