SOURCE: Plays a few minutes then stops, and will not play any dvd
ITS THE MOTOR ITS FREEZING ON YOU NEEDS TO BE REPLACED
SOURCE: Lost signal to DVD player
There is a 12" black ribbon cable that feeds from the mounting unit to the lcd. You can see it when you have the lcd fully open right in the center where the hing is. I am curently working on this problem myself. this is the second time I have had to take it out off the ceiling and disassemble the whole DVD. It seems to pinch it in half. Ive owned this for 5 years. Good Luck....
SOURCE: Motorola, M25, orange-Won't play
Likely not new but worth the try. Had reviewed various other POSTS, and suggestion to take out battery and let sit for a while. Often cures unknown ills. Took out the new battery that did not work, let it sit overnight, put battery in again next morning and it booted up. This was done after, changing three batteries, after taking in/out the SD card (no real reason, but figured why not) and, after a subtle BANG on each of the corners of the unit......
SOURCE: Turn signals sometimes don't work
Change the flasher to an electronic unit. They are far less likely to give you trouble.
SOURCE: sony dvd player will not play dvd's
try using a head / lens cleaner disc a couple of times.. that usually works for me
