I cant seem to play dvds on my neon flat screen tv. The dvd player is connected by a scart cable to the tv, the power works. The dvd player has worked prviously with this tv, but the last few times weve tried it has said no signal. The DVD player is Packard Bell.
It depends on your connections for one thing. I did find this piece of information on the DVD player:
"One thing they do not state (in the manual) is that if you are playing it through your Scart socket to your TV. Your TV's Scart socket must be PAL60 compliant".
If they both have HDMI sockets I would get a HDMI cable and connect via that. You will also get a better picture than a scart.
If you are using a scart the connector can also become faulty either inside or a faulty pin so check that too.
depends on the tv and dvd player. old dvds you plug in the cable with three colors. red white and yellow to the tv input of the same color. now a days dvds and flat screens use the hdmi cable.
First of all you have to connect only one SCART cable ( one end to TV and the other to DMR ).When you are watching a program on TV select the DMR source ( input selector ) to SCART. Just press the record button with a blank DVD inside and it will record. Some Digital broadcast might have copy protect content which will prevent the recording from happening.
In many cases by connecting the DVD via a scart cable (depending in what country you live in if your system supports it)
the dvd will send a signal to the TV to switch over to RGB mode when you start playing the dvd. Rember to make sure the scart connectors are firmly pressed into their sockets on both tv and dvd.
Also if you found out how to switch channels directly on the TV try to go through them ...you might find the AV channel that will show the picture from your dvd.
I had the same problem, after reading the forums and playing around for a while I cracked it. It was to do with the output from the DVD player, in the DVD player setup I changed the output from RGB to s-video and bingo! Hope that helps
hello ,i fixed this problem on a dvdrhd400 i picked up off ebay with same fault. played dvds perfect but no audio coming in from freeview or scart (this is not a firmware update problem). the problem seems to be the capcitors on the tuner board (long retangle board at back which scart connects to) theres a 100uf 10v-16v capcitor (sorry cant remember if voltage was 10v or 16v as i fixed this a month ago and system as been working perfect and dont want to take it all apart again) its in the middle of the board off to one side with afew other 1uf caps around it. replaced it with a 100uf 25v cap (higher voltage is fine as long as same value) Capcitance meter was reading cap as bad. bingo worked perfect ever since.
You MUST connect the recorder to the Tv with a SCART cable that is why you are not seeing anything.
I suspect you are using only the RF or Ariel Cables
If you have it connected with the scart cable you must choose the AV channel on your TV remote.
