Harman Kardon AVR 430 7.1 Channels Receiver Logo
Posted on Jul 01, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No audio for DVD/CD inputs
I can not get the OSD to display on the TV and the receiver continually says that the DVD connection is analog when it needs to be opt1. It had been working last week and now it won't play any sound for a movie or a cd. The display selection will allow me to switch to opt1 and then it resets to analog after a few seconds. I've tried resetting twice with no luck on getting the OSD or the input signal to be correct. Any thoughts/ideas?
Grubhead
Level 3:
  • Harman Kardon Master 5,755 Answers
  • Posted on Jul 02, 2017
 Grubhead
Level 3:
Answers
5755
Questions
Helped
1662382
Points
11417
Has the DVD settings been altered so that it's now putting out an analogue signal?
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Mar 19, 2007
SOURCE: Sound is There Then its Gone!
You will need to trouble shoot the audio output amp section. It sounds like the unit is in a shut down or a protection mode. Good Luck
Anonymous
  • 417 Answers
  • Posted on Apr 07, 2010
SOURCE: Harmon/Karden AVR 230 Surround Sound Receiver
Use your remote to get into the Menu. Look for something called audio, or audio properties. In there you can choose your inputs (sources) and output choices.
On the remote itself, there should be a button called input, or source. That would be for things input to the TV.....such as dvd, vcr.
Testimonial: "Thanks for the great advise. My entertainment center is up and running and life is good!"
Anonymous
  • Posted on Oct 31, 2010
SOURCE: harman kardon avr 140 - all displays work but no sound
I have an HK AVR140 all of the displays work, even shows when a digital connection from the Blu-Ray player is connected but no audio comes from the speakers! I found some information that HK does not have DC protection so when there is a problem muting Circuit is initiated on the main Amp. I called HK and they want me to send it in to a service dept that is not close at all. Any ideas? Or is there a way to by-pass the muting circuit somehow?
Anonymous
  • Posted on Feb 10, 2011
SOURCE: Multi room will not play
I have a Marantz 7.1 AV receiver (sr5500) and I run a 5.1 set up for home theatre and use the 2 extra channels to run a pair of outdoor stereo speakers... When I first set it up I also found I could not get a digital signal output, only analog, after reading the manual(!) I discovered that it can only output an analog signal...so I have used the phono outputs on my blu-ray player into the CD input of the AV amp and play CDs outside through this and it also outputs the optical digital signal into the AV amp through the DVD input...my iPod also plays through a dock and it's analog output to the speakers outside through another (CD-R) anolog input on the amp... Hope this helps
Anonymous
  • 8546 Answers
  • Posted on Apr 01, 2011
SOURCE: My HK AVR-132 doesn't process
If you're processing digital audio into the reciver via the TV instead of directly from the source it REALLY originates in (Cable, for example), you are wasting good expensive optical cable and introducing opportunities for digital data problems. I always run the BEST audio and the BEST video directly from their prinmary sources to the BEST electronics that can handle each one. That means they take entitrely different electronic routes from their origins to my eyes and ears.
You need to evaluate what might be happening to the audio on its way (unnecessarily) through the TV to the receiver.
I have a Yamaha RX-v1800 amplifier. Need help connecting a Bluetooth music receiver
To connect the Bluetooth music receiver to your Yamaha RX-V1800 amplifier, you will need to use one of the available input options on the amplifier. The Yamaha RX-V1800 should have various audio input ports, and the specific connection method will depend on the output options provided by your Bluetooth music receiver. Here are the general steps to connect the receiver:
  1. Identify the audio output options of the Bluetooth music receiver: Check the output ports of the Bluetooth receiver and determine what type of connection it supports. Common output options include:
    • 3.5mm headphone jack (analog)
    • RCA (analog)
    • Optical (digital)
  2. Choose the corresponding input on the Yamaha RX-V1800: Depending on the output options of the Bluetooth music receiver, you need to select the appropriate input on the amplifier. The Yamaha RX-V1800 should have various input options, such as:
    • AUX (usually a 3.5mm stereo input)
    • CD (analog RCA input)
    • DVD/BD (analog RCA input)
    • OPTICAL (digital optical input)
  3. Connect the Bluetooth music receiver to the amplifier: Use the appropriate cable or adapter to connect the output of the Bluetooth music receiver to the selected input on the Yamaha RX-V1800. Here's how to do it based on the different output and input options:a. If the Bluetooth receiver has a 3.5mm headphone jack (analog output) and the Yamaha amplifier has an AUX input (3.5mm stereo input), use a 3.5mm to 3.5mm audio cable to connect them.
    b. If the Bluetooth receiver has RCA outputs (analog) and the Yamaha amplifier has corresponding RCA inputs (CD or DVD/BD), use an RCA cable (red and white connectors) to connect them.
    c. If the Bluetooth receiver has a digital optical output and the Yamaha amplifier has an optical input, use a digital optical cable to connect them.
  4. Set the input source on the amplifier: Once the Bluetooth receiver is physically connected to the amplifier, you'll need to select the corresponding input source on the Yamaha RX-V1800. Use the amplifier's remote control or front panel to select the input source you connected the Bluetooth receiver to (e.g., AUX, CD, DVD, OPTICAL, etc.).
  5. Pair and play: Turn on the Bluetooth function on your iPhone, put the Bluetooth receiver into pairing mode, and pair it with your iPhone. Once paired, you should be able to play your music from the iPhone, and the audio will be transmitted to the Yamaha RX-V1800 amplifier for playback.
Please note that the specific labels of the inputs on your Yamaha RX-V1800 might differ slightly from what I've mentioned, but the general concept of connecting the Bluetooth music receiver remains the same. Always refer to your amplifier's user manual for the exact location and naming of the input ports.
2helpful
Can't access osd on screen display from remote control
Have you checked to make sure your TV is on the correct input?
It should be on the input the Receiver is connected to in order for the OSD to appear .
2helpful
Can I hook up this receiver to a Panasonic Viera tv tc-L32C3
U need to get a digital to analog converter for the tv digital outputs on "tv mode." Connect the analog outputs to the audio input of receiver. I had same hassle with my Viera till I got another receiver that would take direct digital input - no more need for converter.
I have a new Denon AVR 1911 receiver all hooked up to my input devices and output thru a single HDMI cable to my Samsung LCD tv.... problem with getting audio from my DVD player: my DVD player is older...
Not likely that all those things are faulty.
The TV and DVD player make and model would be helpful to know. I would recommend running its BEST digital audio to the receiver and its stereo analog audio to the TV just in case you want to watch and hear the DVD in a lo-fi setting without the Denon. I generally advocate for connecting anything high-end (audio or video) ONLY to equipment that can use it or enhance it. Otherwise you may just be wasting expensive cable and adding unnecessary hops and connections that can fail.
Why do you want the audio to go from the DVD to the TV through the Denon? Are there no speakers on the Denon? Modern TV's have lots of inputs for the flexibility I recommend but rarely have decent audio or speakers.
I have a LG47" tv
Your DVD audio is sent directly to your receiver - not to you TV. That's why you can hear the audio on your stereo. The TV audio is not being sent anywhere - it is "stuck" in the TV and is amplified and sent to the TV speakers. Since the TV speakers are off, you don't hear anything. In order to listen to the TV audio on the stereo system's speakers, you need to send it to the receiver.
You need to have a pair (left + right signals) of audio cables (assuming you wish to listen to stereo sound) from the TV's Audio Output jacks to a pair of Audio Input jacks on the receiver / amplifier. You can use any unused input - CD, Video, Tape, Sat, etc. If you use Tape or Sat audio inputs, when you wish to listen to the TV audio, you must select the Tape or Sat input on the receiver.
Do not send more than one signal to a set of inputs on the receiver. Typically, a CD, DVD and Sat inputs offer two or more of the following types 1) Analog audio. These are the older RCA jacks that have been around since the beginning and require separate cables for left and right channels. 2) Optical inputs. This is the newer digital interface that provides for Dolby Digital (and others) format sound over a single fiber optic cable. 3) Coaxial inputs. This jacks looks like an RCA jack, but usually has an Orange ring - instead of the Red & White rings that analog RCA jacks have. They use a single coaxial cable. 4) HDMI input. This jacks carries both digital video and digital audio signals. If you are using an Optical input for the DVD on the receiver, do not use any other unused analog or digital inputs associated with the DVD to "piggyback" another device like a CD , VHS tape, etc.
I hope this helps and good luck! Please rate my reply. Thank you.
Adding another device to the system
Well, if analog works for you connect the CD player's analog RCA cables to the VCR inputs.
Can you imagine why you NEED to have the TV audio coming into the receiver from the TV? Are the TV's audio system or speakers superior to the audio section of every other source of TV-related programming? We hope not. Does the TV receive any programming that the receiver can not? Maybe games. I imagaine this MIGHT justify running analog TV audio back to the receiver.
Your cable box and your DVD player have both digital and analog audio outputs. The gray area is what your TV has for audio inputs. It could survive with simple RCA analog audio in from both and none to or from the receiver. Then you could watch Lo-Fi cable and DVD's without the receiver turned on.
That would free up the TV analog audio input for other things.
I imagine your DVD player is using one of the digital inputs on the receiver. If you have one each optical and coaxial audio output among your DVD and Cable Box you could place them in the two available diigital inputs.
Now, what about the CD's digital output? For stereo music you're not likely to be able to hear any difference between it and the analog input BUT it can still be connected digitally IF it has a coaxial output. Coaxial digital inputs can be shared.
Get an RCA-splitter and join the two units entering the coaxial audio input just before they enter that connection. Either will work just fine if you TURN THE OTHER ONE OFF when you want to us it.
How do I get the " OSD" to work!
Make sure that you are selecting the correct input on the TV for which input you are plugging the receiver into. Then press the OSD button on the receiver remote. If that doesn't work, try plugging the S video into a different video input, or use a different video input cable such as from the composite connection of the monitor out. Some reasons for having to do it this way is that some televisions may give priority to one input of identical type which is usually S video. For example if you are using the S video input on the front of the TV with a different device and then plug another S video cable to another input elsewhere on the TV, it may only display the picture through the S video on one input because it is using the same circuitry for both S video inputs and can't display picture from both of them simultaneously nor can you toggle between them even if the other device is not turned on. HOWEVER, there MAY be a way around this as well...try your picture-in-picture (PIP) and toggle to the PIP input that your receiver is plugged into. Still then if that doesn't provide you with the OSD of the receiver menu, then just change one of your S video inputs to a composite input.
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
My OSD does not come on
Try plugging a video rca cable into the "monitor" on the back of the mixer (second down or something like that) and then to your tv. This pumps the osd signal to the tv where you can manipulate the menu options.
Think this analogy:
remote = keyboard
receiver = computer
tv = monitor
You need a connection ultimately to the tv for the osd to work.
Top Harman Kardon Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Sean Wright
Sean Wright
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
