Fig. 7: Cylinder head bolt removal sequence
Fig. 13: Head bolt torquing sequence-1970-83 models
After repair job, temporarily install and tighten the two center (right and left) cylinder head bolts to 14 ft. lbs. (18 Nm).
Install the camshaft sprocket together with the timing chain onto the camshaft. Make sure that the marks made earlier, line up. If the chain will not stretch over the sprocket, the problem lies in the tensioner. Refer to the Timing Chain removal and installation procedure for the timing procedure, if necessary.
Install the cylinder head bolts. Note that two lengths are used. Tighten the bolts in sequence.
1970-71 models:
Tighten the bolts to 33 ft. lbs. (43 Nm)
Tighten the bolts to 47 ft. lbs. (61 Nm)
1972 models:
Tighten the bolts to 55 ft. lbs. (71 Nm)
1973-83 models:
Tighten the bolts to 30 ft. lbs. (39 Nm)
Tighten the bolts to 44 ft. lbs. (57 Nm)
Tighten the bolts to 54-61 ft. lbs. (70-79 Nm)
To complete the installation, reverse the removal procedures. Adjust the valves to a preliminary COLD clearance of 0.2mm for the intake and 0.25mm for the exhaust. Operate the engine until it is at normal operating temperature, retighten the head bolts (loosen them slightly and retighten to the final torque figure) and adjust the valves to the HOT clearance specifications.
Hope this helps; remember to rating this answer and leave some testimonial comment about this.
