I have a Hitachi Ultravision 61 Rear Projection unit. Either via the remote or by pressing the power...
(More)
I have a Hitachi Ultravision 61 Rear Projection unit. Either via the remote or by pressing the power button, there is no power to the unit and the red power light does not come on.
does the screen come off a hitachi 52 in tv that is about 7 years old I think the model number is...
(More)
does the screen come off a hitachi 52 in tv that is about 7 years old I think the model number is 50gx20bv1c011706? I have one that has water spots on the inside of the screen and was just wondering how to clean it!
while watching tv there was an audible "zzzzzttt" and then the screen went blank...now...
(More)
while watching tv there was an audible "zzzzzttt" and then the screen went blank...now will not power up...is there a fuse that needs to be changed, or something that I can do, or is it time to replace this 10 year old model...
61 inches Hitachi model Number 61SDX01B. When i plug it in, and turn it on, i can clearly hear the...
(More)
61 inches Hitachi model Number 61SDX01B. When i plug it in, and turn it on, i can clearly hear the clicking noise of the tv and the red light on the front of the tv also light up, Unfortunatly, there is no image whatsoever and no sound.
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able...
written by misenhei
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
