20 Most Recent
Nokia E61 Questions & Answers
I have forgot my lock code on Nokia E61
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
1/18/2013 3:22:28 PM •
Nokia E61
Answered
on Jan 18, 2013
How to reset nokia E61 mobile
1)Try this first *#7370# and enter Default code 12345 or 00000
2)If the Above doesn't work Try *#7780# and enter code 12345 or 00000
3)If the above 2 doesn't work, then finally try this, Switch of the mobile and press * + 3 + Call button + switch on the mobile and hold the 3 keys till the nokia welcome screen displays.
Hope this Helps.
12/24/2010 8:41:27 PM •
Nokia E61
Answered
on Dec 24, 2010
Certificate error of nokia e 61
Well, are you using legal software? When you are using some pirated software, Symbian 60 V3 uses this certification, and you cannot use that software ...
Darko, Serbia
4/17/2009 3:58:24 PM •
Nokia E61
Answered
on Apr 17, 2009
Nokia e61 wont charge?
check with a different charger, this happened to me. I got mine started up just by charging with the different charger. Just try.
3/31/2009 12:20:23 PM •
Nokia E61
Answered
on Mar 31, 2009
How to Install Nokia MTK USB Serial Port Driver
How To Install Nokia MTK USB Serial Port Driver: Step 1: First Download (WinRAR/ 7-Zip) Software And Install On Your Computer. Step 2: Download Nokia MTK USB Serial Port Driver, Then Right Click And Extract Files On Your Computer. Step 3: Open Nokia MTK USB Serial Port Driver Folder. Step 4: Now Select (Nokia MTK USB Serial Port Driver.exe) And Right Click To Select Run As Administrator. Step 5: And Then Next- Next- Finish. Step 6: Then Restart Your Computer. Step 7: Now Your Nokia MTK USB Serial Port Driver Install Complete.
How can i get my nokia c2-01 from test mode?
To exit test mode, turn off phone.
Press *3001#12345#. Scroll up 1 to FIELD TEST (some phones may say NET MONITOR instead of FIELD TEST) and SELECT. Scroll to ENABLED and press OK. Turn phone off and then back on. Signal strength is the upper or lower left number. After test mode is enabled it will stay in your regular menu. To easily get in or out, press MENU, up 1 FIELD TEST and SELECT or OK. Dial 00 to get out and 01 to get back in.
