Cable works. Tried unplugging tv and holding power button. Can't find network settings.
SOURCE: 42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
SOURCE: green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
SOURCE: Western DIgital 500 GB litght flashes but not working
I discovered that the wrong power adapter was plugged into the Western Digital My Book which is why it was blinking two times a second and fried it. Plugged in a 24v instead of the 12vThe tech support person at Western Digital ignored the information of the blinking light. I fixed the hard drive issue by removing the cover (no easy task) and installing it as a slave drive on my computer. I am backing up that hard drive using another Western Digital My Book.
I would suggest to anyone who has the problem of frying their Western Digital hard drive to make it a secondary drive on your computer. My item was under warranty, but all they would have done is replace the product and not recovered the data. They gave me references on whom to send the problem hard drive to.
There are a couple of videos on youtube showing how to remove the cover. I wound up using credit cards and a DVD to pry it apart. I was fearful that a screwdriver could create noticeable tampering.
SOURCE: Dish Network "Blue" Smart Card upgrade... Now get only "015"
The solution is usually a simple one and that has been suggested already but I will ask you to try one thing first. Remove the new smartcard and do not put one in. If the receiver still displays a picture and yoou can get to menu 611 run a check switch. After this is performed cancel out of the screens and re insert the new smartcard. Once the system comes back up perform the same steps as you did before with the smart card removed. If this fails you can try the solution they offered which was to update the sofware. There is no reason your software should be outdated if you were using this receiver before the new smartcard but try anyway as it may SOMEHOW work. Using the remote turn the receiver itself off. Allow the receiver sometime to turn itself back on-this could take awhile so plan this when you leave for work or are going to be gone from the house for sometime so you do not get bored waiting for this to occur. If the receiver has not turned back on in 45 minutes or more then the receiver will either need replacing -which i suggest- or they will try to send you a new smartcard if you talk to Cust service. Tell them you want a service call to fix the receiver. While you have them on the phone verify your receiver number and the new smartcard number which is on the back of the card and ask them to send a hit to the receiver. If the receiver has not been associated with the new smartcard or if the smartcard was not loaded with all of your programmming this should fix the issue. Thanks for using Fix Ya.
