SOURCE: Lexmark E238 prints about two thirds of a page and stops
Please follow the instruction given in this link:
clear the paper jam as given in this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=37:1:0:512:0:0&framed=&docid=ENUS25568&relevance=1
SOURCE: paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
SOURCE: Canon PIXMA paper jam
Hi there ok gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: my canon pixma ip2000 will not print. The paper
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
SOURCE: my canon pixma ip6600d printer has started to
Hello, Jim.
From your description, sounds like the paper feed stepper motor is failing.
This is a part that needs to be replaced by a professional repair service. I'd suggest to contact service in your area or online to see if the repair would be cost-effective.
I suspect that your printer is no longer under warranty. Otherwise, I'd suggest a return to Canon for a replacement.
Hope this helps.
