Televison & Video Logo
L Steele Posted on May 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I repair the color on my Samsung LCD TV. I can still see the picture but 3/4 of the TV goes green/purple/pink and the bottom 1/4 has normal color.
I have Samsung LN32D403E4D TV and the color in the tv started changed. There's 1 inch portion at the bottom of the tv with normal color and the rest has green and purple coloring.
Electro Med Services
Level 3:
  • Samsung Master 6,694 Answers
  • Posted on May 28, 2016
Samsung Master
Level 3:
Answers
6694
Questions
Helped
1872753
Points
21433
The T con Board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
Wavy picture with blue and purple color.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
There is green and pink on color on half of my lcd
I did some research and I found this link that will should you the schematic of the LCD technology,It sounds like one of you LCD color ships is not working properly,your TV has 3 ships (BLUE,GREEN,RED)
you can see how it work; http://www.oerlikon.com/ecomaXL/index.php?site=OPTICS_EN_lcd_projector .Whay happening is that due to the high density the lamp this ships tent to wear out and the three major color don't mix properly causing the color discoloration on your picture.You can find the parts you need at DM http://www.discount-merchant.com/?click=52978 (The correct diagnostic can only be made be a tech) I hope this info helps you please keep us posted .
Pink picture with no green
take the color to b/w and retune
Zenith R57W46 bottom bowing and color off and double lettering
*Screen Looks 3-D
*Colors wont align
Green and purple band of color
*Screen Looks 3-D
*Colors wont align
2answers
Samsung TXN3275HF 32" tv - purple picture
Chuck the TV - probably It depends on the repair facilities available where you live. In big urban areas the cost of staffing a repair shop is such it can cost nearly as much per hour just to look at an item is it does to buy the next one-plus you get all the latest features.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
