SOURCE: my fridge compartment is warm
Check the freezer for frost on its back wall. The refrigerator gets the cold air for cooling from the freezer section. If you have frost on the back wall you have a problem in the defrost circuit. There are three parts involved in the defrost of the coil. Heaters, thermostat or defrost thermostat, and timing device. If your model has a mechanical timer you can located it and rotate the clutch head screw Clockwise very SLOWLY until you hear one click. This puts the freezer into the defrost mode. After 30 minutes if the defrost takes place and the refrigeration does not restart, rotate the clutch head screw a little more and it will start. This tells you the timer is the problem. If it does restart by itself and defrost does not take place your problem is in the heater of defrost termination thermostat. The timer is generally located near the controls for the temperature.
SOURCE: leaking in the freezer compartment
This is a common problem with all refrigerators. The problem is most likely to be in the defrost condensate drain line. Beginning in freezer and making its turns to condensate pan below your refrigerator.Send your model number and I will be able to point out where. Thank You
SOURCE: Type: RT24MH2 Freezer TOP Fridge BOTTOM The freezer
Hi.
The problem is usually the defrost system. In some case a broken of frozen damper system (the air fan) can give the same problem. Even if it is not really common the temperature control system may also fail causing insufficient cooling in the fridge.
Try first performing a complete defrost (leave unit off overnight or for several hours). The fridge will restart cooling afterward. The fresh food section should be cooling again as well.
If after defrost, the problem does not occur anymore, than it was a blocked damper motor. Usually because of ice formation. If you still get the problem after few days or week, then the defrost system is not working. In that case the repair is done accessing the evaporator, whose coil is probably frozen, and testing heater, fan and thermostat. The defrost control must also be checked. Here the description of the job done on a Kenmore. The parts in the evaporator and the testing procedures are the same: When the fridge is not cooling ....
Regards.
Ginko.
SOURCE: power cut has caused samsung
Your computer has failed & needs to be replaced.Your looking at 300-500 dollars to repair.
SOURCE: I have a SR-L32 model
Check to see if freezer coils are frozen If so you have a defrost issue
