20 Most Recent LG LRTC19314ST Top Freezer Refrigerator Questions & Answers
i use a basting syringe filled with clorine bleach..........works for me.
LG LRTC19314ST... | Answered on Jan 23, 2011
If freezer is warm though you've raised the temperature, it is a major problem. If you've valid warranty then call the dealer and they'll definitely fix every problem.
If warranty does not covers, then you should call some A/C and Refrigerator mechanic(you will definitely find some in your local area) to fix this.
LG LRTC19314ST... | Answered on Nov 12, 2010
to save the most electricity.??? turn off // ha ha // to run any frig properly try to keep ref side ( fresh food at 36 to 38 deg and freezer if it has ice maker around 0 to 5 deg . . . to save power . keep the coils clean and door seal clean . make sure doors close properly and seals are good . mm
LG LRTC19314ST... | Answered on Sep 23, 2010
Ok do this. Boil some water in a pot then use that to defrost the freezer. This is caused by ice build up in the vent that is keeping the cold air from coming into the refrigerator. Make sure it is defrost completel though cause the ice that is built up is mostly inside and can't be seen. That will solve ur problem I guarantee. Then set the temperature to normal. Like half way. This keeps the frost from building up. Believe it or not as refrigerators get a bit older they actually get even colder and therefore frost build up is more likely. Since no refrigeration can be made completely leak proof, small amount of the freon has leaked out older fridge, and this actually cause it to get colder. You don't need a service technician just defrost then set to a lower setting thats it.
LG LRTC19314ST... | Answered on Feb 12, 2010
try a flexible curtain/net wire to rod from top to bottom. and check that the outlet at rear of unit above the black compressor to the tray is unobstructed..
LG LRTC19314ST... | Answered on Dec 17, 2009
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
LG LRTC19314ST... | Answered on Mar 23, 2009
Have a look at this video. I am sure it helps resolving this issue.. Click here
LG LRTC19314ST... | Answered on Oct 15, 2008
first maybe Adjustment button has locked or LED is burn, other refer(troubleshoot) & user guide for more guidance
LG Refrigerators | Answered Yesterday
I would set the fridge in the middle, check it in a couple hours and see what the temperature is. I like my fridge too be at 36 degrees. Adjust the temperature control as needed to get the temperature to what you like. Do the same with the freezer, I like my freezer to be around 28 degrees. My big freezer I keep at about 10 degrees.
LG Refrigerators | Answered on Nov 09, 2018
Out west here (Colorado) general word is don't buy LG because they are either unfixable or take huge money to repair. Suggest you call around and find an honest (!) independent repairman who will agree to try and fix if it's simple, but LG keeps a very tight chain on parts sales. Might be as simple as adjusting the hinges (top and bottom) to see if there any strange tension on the doors.
LG Refrigerators | Answered on Nov 02, 2018
My ice maker on my LG has an interior door to access the ice maker chest. The latch is stuck and the door won't open. The upper hinge is accessible and easy to remove, but the lower hinge is not. How do I fix this latch?
it is a dead short so could be the element, compressor motor , start/run capacitor or bare wires
call a technician for the diagnosis
LG Refrigerators | Answered on Oct 26, 2018
LG LRTC19314ST Top Freezer Refrigerator Logo
10 questions posted
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
best setting freezer
  • Refrigerators
