20 Most Recent Amana AFD2535DES French Door Refrigerator Questions & Answers
I solved my problem by going someplace that wasn't going to charge me!
Amana AFD2535DES... | Answered on Feb 02, 2019
Is the display flashing when you try and use it or can you hear the dispenser door opening and closing rapidly (clicking or clapping sound)? These are prone to the board going bad and losing the dispenser. Is the "ice" light lit on the dispenser? The touch pad could be bad too. Do you hear the auger motor turning the ice when you press the dispenser? or just the "shhhhhhh" of the water coming out?
If there is ice in the bucket then that is not the problem. Dump it and listen if you hear new ice drop to verify.
There is no such part called an "ice element". Ice maker-yes.. Heating element-yes.. Ice dispenser-yes
Amana AFD2535DES... | Answered on Apr 10, 2018
Possible the source of the trouble you are having is the bracket might not be available or available separately.
Most parts lists have an exploded drawing showing all the parts and these are an invaluable aid to obtaining the correct spare parts.
I suggest you ask the service department to fax or email a drawing to you.
Amana AFD2535DES... | Answered on Mar 28, 2017
There a number of reasons that ice forms on the evaporator coil. One is no air flow or not enough air flow over the coil. Another reason could be the unit is not going into defrost. There will be some ice on evap coil most of the time, but the defrost cycle should remove the ice. If there is not enough air flow across the coil to take away the cold, the coil will build up ice. I would check the defrost cycle and make sure there is not an obstruction in the circulating fan system. On the older refrigerators you could turn the defrost timer to defrost, but the newer models have circuit boards, and I am not sure how to force the defrost.
Amana AFD2535DES... | Answered on May 15, 2015
the evaporator coil is frozen. i have had this problem for a while. i just figured it out. i believe the compressor is not shutting down. everone else is talking about a bbad fan but that might be a symptom of a frozen coil. i am further investigating.
elofsonm@aol.com (self proclaimed worlds best troubleshooter)
Amana AFD2535DES... | Answered on Apr 11, 2014
there is two adjusters at the front corners of the fridge
Amana AFD2535DES... | Answered on Jan 13, 2014
Amana AFD2535DES French Door Refrigerator Logo
214 questions posted
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Carmen Mikulic
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
compressor unit never stops
  • Refrigerators
