Dell 926 All-In-One InkJet Printer Logo
Posted on Jul 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Has ink but will not print - Dell 926 All-In-One InkJet Printer
Anonymous
Level 2:
Scholar:
  • Expert 71 Answers
  • Posted on Jul 16, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
71
Questions
0
Helped
31321
Points
155
Please replace with original genuine cartridge and try for this. Because the printer is seldom used and the ink got dried up in the catridge. Atleast once in a day print one or two pages daily to sort out this issue.
Best of Luck always.
4helpful
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
7helpful
Dont know how to replace printercartridges in mx700
Install the print head or ink tanks properly following the procedure If reseating or reinstalling to clear an error, the ink tanks and print head must first be removed.1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.Note: When the top cover is opened more than ten minutes, the print head moves to the right side.If this occurs, close the top cover, and open it again.2. Open the paper output tray.Note: When installing the print head, roceed to step 3.When installing the ink tanks, proceed to step 6.3. Raise the print head lock lever.4. Pull out the print head from its package, then remove the orange protective cap from it.Note: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>.Doing so may cause printing problems 5. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.6. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.7. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.Note: - Do not touch the ink tank contact <1>. Doing so may occur printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
8. Insert ink tanks into the print head.1) Insert the ink tank into the Print Head.(2) Press on the 'PUSH' mark on the ink tank until the ink tank snaps firmly into place.(3) Ensure that the ink tank lamp lights red.Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes. On: The printer is ready to print. Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank. Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.- Off: An error has occurred and the printer is not ready to print.10. Close the top cover.Note: When starting printing next time, the print head cleaning launches automatically.During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
3helpful
Check ink u163
This is Canon's explanation of what this error refers to:
Ink has run out.
Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
1helpful
2answers
My Xerox 8400 is printing the wrong colors. Where it's red, it's printing a brown shade and where it should be grey, it's printing green. My logo is grey and red and it's printing all grey, but not the...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
This problem is common in situations where a lot of black and white printing is done, with very little colour.
Alternatively, it could be that your wiper/cleaning blade is not cleaning the head properly and is smearing the different coloured inks across the head, or possibly that your printhead is leaking colours but I think the first solution should solve your problem.
Hope this helps.
1helpful
2answers
Colours are not true, grey is brown
You are getting leakage from one color cartridge to another. Do deep cleaning and run nozzle check. You may have been using non-Cannon inks. They can corrode the ink cartridge seats due to inferrior quality ink. You may need to replace the print head. Check out Cannon web site under this printer support. Print head is in the $50 neighborhood.
2helpful
2answers
Service error 5600 appeared when the printer stop
Dear budg,
Error code 5600 in S200 is No Print head Error indicator. In this case, the print head of the printer is faulty so that the printer cannot detect the print head. About the print out, please check if there is enough ink in ink tank to print. If there is enough ink to print, means this bad print out caused by the faulty print head. It seems that you to replace the print head.
Regards,
1helpful
HP Deskjet D4160
hi,
Ink-backup mode lets you continue printing with one print
cartridge when the other print cartridge has run out of ink.
Ink-backup mode allows the printer to operate using only one print cartridge. It is initiated
when a print cartridge is removed from the cradle.
Exiting Ink Backup mode
Install two print cartridges in the printer to exit ink-backup mode.
Cheers !!!!
2helpful
2answers
Change ink cartidges
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  1. Raise the print head lock lever.
  2. Pull out the print head from its package, then remove the orange protective cap from it.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  3. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  1. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    <4> Tape is completely removed.
    <5> Tape remains.
  2. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  3. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  4. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  5. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
Getting error 681 "more thn one magenta tank instaleld" on MP530
    <5> Tape remains.
    N
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
