First, try a factory reset on the camera just to be sure it's not something that easy to fix. Also, format any SD cards first in your PC and then format them in the camera if it will allow it.
If that doesn't work make sure the pins inside the card slot are not dirty or damaged. You'll need a strong light and maybe some magnifying glasses. Try blowing a burst of canned air inside but make sure you're holding the can level so you don't spray the propellent.
Go in the camera options and format the card. If your camera does not have this option or it can't complete the format it means that : Your card might not be formatted with the correct File System. Move your SD Card to a computer with card reader and Format with FAT32 File System the move it to camera. If the camera gives the same error, format the SD card with the NTFS file system the try again in your camera. If the SD card still don't work try FAT Fyle System.
This is a problem with the memory card. I don't know why your camera is not giving an error message of some kind- it seems to know that it can't store pictures there.
Probably the first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
If the memory card replacement is an SDHC model card the Kodak z740 will not work with it. The memory card has to be a standard SD card of 2 gig size or less to properly function. Take card out and turn on camera. See if you get same error. You should get missing card error but otherwise be able to operate camera controls such as zoom, flash, etc. If that is fine find old card you used and place back in camera... or purchase a standard SD card from Walmart for 10 dollars
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
If you have a card reader or a printer with an SD card slot in it, try formatting the card or deleting all files on it using a PC. My laptop has a slot built-in I'm able to use. Check out your options. Try formatting it outside of your camera. I've heard of some card swapping between brands of cameras doing crazy stuff as you are experiencing.
The specifications on page 25 of the User's Manual state that only SD cards between 8MB and 1GB in size can be used in this camera. When I tried a larger-capacity 2GB SD card in this camera it reported that the card needed to be formatted even though the SD card worked fine in my desktop PC's SD card slot. Verify that the capacity of the SD card you're trying to use is 1GB or less, I suspect the error report about formatting is due to the SD card being larger than the camera can handle.
The problem with the c350 is that it does not accept a memory card higher than 1GB! I found that out through the Kodak website and not in the User's Guide!
