It is recognised by pc and i was able to download the pictures but even a new sd card is not recognised by the camera. It keeps saying to check the SD card
SOURCE: Can I use a memory card SD 2Gb in a camera Samsung Digimax S500 ?
Yes, you can use a 2 GB SD card in your camera.
SOURCE: s d card wont work
hi my understanding the camera can take only a max SD Card size to 2GB you may wanna check on that
SOURCE: Can I my SD card won't format, I just keeps saying
Check your manual to see if you can use an SDHC card. Some cameras can't.
SOURCE: Samsung digimax 4010 camera has error message.
tis logical that sumsung digimax 401 cannot procees a 2gb memory card, use 1 gb will format ok.
SOURCE: I put a new sd card in my camera and it says check
Your model camera can only use up to a 2GB standard SD cards, and not 4GB or higher SDHC cards. There are several other possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before the SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Testimonial: "Thanks so much. I did not know that and a 4gb is what I had. That was very helpful and very fast response."
