20 Most Recent Panasonic Lumix DMC-FZ8 Digital Camera Questions & Answers
Hi and welcome to FixYa!
Please try to remove the battery and let it sit for atleast 5mins. then reconnect it again. This should reset the system and can resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one!
Panasonic Lumix... | Answered on May 31, 2019
The issue lies with the lens assembly electronics and/or motor. If possible try another lens. If that one works it is the lens. If it doesn't, it might be the switch control for the zoom action.
Panasonic Lumix... | Answered on Sep 19, 2017
Does it say anything about the lever under zoom levers in your owner's manual?
Panasonic Lumix... | Answered on Jul 04, 2017
Unfortunately no. You can get better video if you turn off auto focus and set the zoom position to the halfway mark . This set up will significantly improve your results.
Panasonic Lumix... | Answered on Mar 06, 2016
You've got two possibilities.
Remove the memory card before connecting your camera to your computer.
Use the "Copy" command in the Playback menu to copy photos from the internal memory to the memory card, then transfer them fro the memory card as usual.
The "Copy" command is on page 108 of the manual: http://www.fixya.com/support/p509855-panasonic_lumix_dmc_fz8_digital_camera/manual-30307
Panasonic Lumix... | Answered on Jan 31, 2014
When you have to ask this question, my guess? you better don't try this.
But if you don't mind how this ends, you could try ifixit dot com. There they have manuals, videos and hints how to repair electronic stuff. They eventually can help you with the correct tools and pare parts, if needed.
Panasonic Lumix... | Answered on Jan 30, 2014
This is called focus pumping, and can occur. Nothing to worry about. If the camera has enough light or there is lots of contrast in the object you want to take a picture of, it will be less. The correct focus is found quicker.
Every camera in autofocus, needs to find the correct focus. Only the bigger and expensive DSLR's, will focus a little faster then the compact camera's. Still Every digital camera has this effect, although not every on is as observing as you I think.
Only when it takes several seconds every time you want to take a picture, it could be an error. But when it was on focus and you want to shoot a second picture from the same situation, and is is quick in focus again. Your camera is ok.
Panasonic Lumix... | Answered on Nov 30, 2013
See the instructions on page 38 of this manual: http://service.us.panasonic.com/OPERMANPDF/DMCFZ8.PDF
Panasonic Lumix... | Answered on Sep 01, 2013
In your menu's look for the entry named "conversion" make sure that it is "off" it seems when this mode is on, flash is forced off.
Panasonic Lumix... | Answered on May 26, 2013
It's the dial on the top of the camera, marked with P, A, S, M, and six icon. See page 20 of this manual.
Panasonic Lumix... | Answered on Dec 23, 2012
Panasonic Lumix DMC-FZ8 Digital Camera Logo
138 questions posted
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
dmc fz8 made when in motion picture
  • Cameras
