Fortunately, your ice maker is repairable. The module is like a little computer. It has a circuitry, a motor and a rotating gear set. The module tells the water solenoid valve when to turn on and how much water to fill the cube tray. Then it reads a sensor telling the module that the cubes are frozen. Then it turns on a heater under the cube mold. After a period the module tells the motor to turn on and harvest the ice cubes. It also has a lever arm on/off switch.
Watch the video. Remove the module from the ice maker. You may need a small flat head ***** driver to pop off the cover to get to it. Inspect the circuitry for any burn marks.
You will need to jump start the ice maker after reassembly and if you decide to just buy a new one.
1.) Insert a piece of 12 or 14 gauge jumper wire into the two holes on the face of the module marked: "T' and "H".
2.) Hold in the door light switch.
3.) After the module starts wait 5 seconds and remove the jumper, while still holding in the door light switch, until the ice maker has completer it's cycle and fills with water. This will not solve your problem. This is how to start the icemaker - not shown in the video
Module Cost: Sears $98.56 + Tax
Ebay $25.00
2.) Ice Maker Water Solenoid Valve: Part Number W10341320.
If your ice maker is filling with water, then the solenoid is working, but the spool valve may be sticking and not closing quickly.
See general replacement video.
Solenoid Valve Cost: Sears $80.00
Search the internet for best price including used.
Go into the Sears website and put in your refrigerator model number. You will get diagrams and component part numbers.
When I serviced these units I had to take the freezer door off to access the ice maker. There are two screws in the front of the icemaker and 2 tong and groves which hold the icemaker to the freezer celling. These tong and grooves in the back on the ice maker right and left corners.
Once the ice maker is free, you will need a small flat head screw driver to wedge into the icemaker connector to disconnect the wiring.
If you are 100% sure your problem is the ice maker assembly, you may want to consider purchasing the new assembly before starting this task. This way you can inspect the top to the icemaker for mounting.
The two screws are either hex or Phillips heads. If it is a hex head you need to make sure the 1/4" hex head can fit into the recess where the screws are located. Some 1/4" hex head drivers are too large in outside diameter.
Before you condemned the ice maker have you considered:
1.) There is a square red reset in the front center bottom.
2.) I assume since you have defrosted the freezer there is not a ice cube jamming the ice maker.
3.) And since you defrosted the freezer you do not have a frozen fill tube.
Last thing; press the red reset button. If the ice maker cycles but does not fill, then you have a water supply problem. This could be a kink in the water line, water shut off valve could be bad restricting 50-60 PSI required pressure, or a bad water solenoid valve. Check the solenoid valve for continunity with your Ohm meter.
generally its the thermostat in the ice maker. or module head of the ice maker. sometimes the parts of the ice maker cost as much as the whole icemaker it self , so when looking at parts get a price on a complete icemaker
The cost depends on where the problem is. For example: If the ice maker is NOT getting water to make ice then it is probably the 2 line water valve solenoid or the sensor on the ice maker that would tell the 2 line water valve solenoid to send water up to the ice maker tray. Both of those replacements will cost you in the neighborhood of $25.00 - $40.00 plus a service call if you aren't able to do the work yourself.
If water is getting to your ice tray, but not kicking out the ice into the bin - that is usually a motor problem. And cost you as much as what a replacement ice maker would cost you.
If your ice maker has stopped producing ice completely first unplug the ice maker and then check it in this order. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:If your ice maker has a small red plastic lever, lower it to lower the wire.If there's no plastic lever, simply lower the wire.In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
hELLO THERE: There's no iceIf your ice maker has stopped producing ice completely, check these, in this order:It
position, the ice maker is turned off. If so, try one of these:If your ice maker has a small red plastic lever, lower it to lower the wire.If there's no plastic lever, simply lower the wire. In
necessary.The
Hello there: There's no iceIf your ice maker has stopped producing ice completely, check these, in this order:It
necessary.The
Hello there: There's no iceIf your ice maker has stopped producing ice completely, check these, in this order:It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:If your ice maker has a small red plastic lever, lower it to lower the wire.If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Change the Water enter dump valve for the ice maker. It is leaking. It
will not shut off & will cause this problem. It`s infrequently
located in the rear of refrigerator ussualy where water line enters the
electrically back of refrigerator. In essence the valve and electric
head can be bought at any Appliance Parts store. It`s not a high cost
part and be bought easily for it is mostly a standard part to buy.
erroneously bring the model number and serial number and they can get
the right one to replace it with.
