When I serviced these units I had to take the freezer door off to access the ice maker. There are two screws in the front of the icemaker and 2 tong and groves which hold the icemaker to the freezer celling. These tong and grooves in the back on the ice maker right and left corners.
Once the ice maker is free, you will need a small flat head screw driver to wedge into the icemaker connector to disconnect the wiring.
If you are 100% sure your problem is the ice maker assembly, you may want to consider purchasing the new assembly before starting this task. This way you can inspect the top to the icemaker for mounting.
The two screws are either hex or Phillips heads. If it is a hex head you need to make sure the 1/4" hex head can fit into the recess where the screws are located. Some 1/4" hex head drivers are too large in outside diameter.
Before you condemned the ice maker have you considered:
1.) There is a square red reset in the front center bottom.
2.) I assume since you have defrosted the freezer there is not a ice cube jamming the ice maker.
3.) And since you defrosted the freezer you do not have a frozen fill tube.
Last thing; press the red reset button. If the ice maker cycles but does not fill, then you have a water supply problem. This could be a kink in the water line, water shut off valve could be bad restricting 50-60 PSI required pressure, or a bad water solenoid valve. Check the solenoid valve for continunity with your Ohm meter.
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
