Sounds like AGC [Automatic Gain Control] circuit section fault. The fault is related with its main board. It will be best to contact any service technician or the authorized service center in this case; as this is not an easy work can be done be a user. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer
Antenna is not hooked up to television.
Problem is caused by television broadcast
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
SOURCE: Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
SOURCE: I have a 32
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. [email protected]
SOURCE: screen goes blank but come back when TV is turned off and back on
Ur tv LCD inverter board it dead.Replaced this LCD inverter board ur tv picture will return.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
SOURCE: last night watching tv, picture cut off (black
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
