I can't open my tv the Green button is flashing and turn off immediatly ? Wich piece should I...
(More)
I can't open my tv the Green button is flashing and turn off immediatly ? Wich piece should I replace ?
Does dust accumulate on the inside of the screen reducing vibrancy & can the screen be...
(More)
Does dust accumulate on the inside of the screen reducing vibrancy & can the screen be removed to clean? (Pertaining to RCA HD50LPW164).
I have the same problem as posted by this person below with the tv not turning on. Press the on...
(More)
I have the same problem as posted by this person below with the tv not turning on. Press the on button, it blinks three times and then nothing, picture or sound do not come on.
By Willtryit on Nov 21, 2007
I press the on button, the light turns green, I hear a light whine and then the on button green light goes off.
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
