Stops with red light and no codes after power on. motor runs briefly (1 second). looked for paper jam,bound up shafts/gears 9
SOURCE: Samsung Printer CLP300
Have you run the Dr. Printer utility that comes with the printer? If not, run that and see what it says. You can download it from the CLP-300 support page at samsung.com.
give this a try
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
SOURCE: phantom paper jam . Samsung clp300. Flashing red light
you clean your printer drum unit wast ink poder drum open and wast ink
SOURCE: rollers won't turn?
DO a powerflee
here are the steps
1) unplug all the cables from the printer including power cable.
2) press and hold the on/off button on the printer for 30 seconds (this will release all the static from the printer)
3) plug back the cables and then try
SOURCE: Samsung CLP300 - All LED lights red and getting very hot when on
drl1069.dyndns.org/Public/CLP-300.pdf Ok above is your service and repair manual, inside is all troubleshooting procedures used by the engineers to troubleshoot and repair these units.
