Panasonic Lumix DMC-SZ5 Digital Camera - Black Logo
d
denise Posted on Oct 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Add space while typing password
Trying to type in password on camera but need space between words. cannot find space icon on camera
Bosse Photos
Level 2:
Sergeant:
  • Expert 232 Answers
  • Posted on Dec 24, 2014
Bosse Photos
Expert
Level 2:
Sergeant:
Answers
232
Questions
0
Helped
45811
Points
630
1helpful
2answers
How do i unlock my dell computer home screen with out a disk
1. windows DVD installer
2. Boot from DVD and choice repair
3. Choice command promt menu
4. Type it: copy c:\windows\system32\sethc.exe[space]c:\ and hit enter
5. Type it: copy c:\windows\system32\cmd.exe[spasi]c:\windows\system32\sethac.exe and hit enter. Type exit and hit enter
6. Press CTRL+ALT+DEL to reboot from hard disk
7. On windows home screen, press Shift keys 5 times. It will activate command promt.
8. Type it: net user [your account] [your new password] and hit enter. Type exit and hit enter.
9. Now you can log in to your windows using your new password.
10. Don't forget to replacing back the sethc.exe or just leave it.
Change password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
2answers
Good Morning, I need to change the password that opens up my compter, In very simple steps can you tell me what to do? Thanks Deborah
If you are running Windows Xp, Go to: Start > Control panel > User accounts> in user accounts click on the account you want to change and then click change my password
Type your current password in Type your current password.
Type your new password in Type a new password and Type the new password again to confirm.
You can type a word or phrase to use as a memory aid for the new password in Type a word or phrase to use as a password hint.
Click Change Password.
And its done.
In Windows 7 or Vista
Go to...
Start > Control panel> User account
In User Accounts under Make changes to your account area, Click on Change password
In the first box, type your old password
Type ur new password in the next two boxes
Type a pass word hint in the last box and select change password. This should do it.
2answers
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
I need to find the WEP password so i can have xbox live on my xbox but it wont let me into my internet because i need the WEP password
From a PC click on start and then click on run type in the run box or if running Vista/7 cmd, when the DOS prompt opens type in ipconfig its 1 word no spaces, then hit enter. The default gateway is your IP address.
Now open explorer and in the address bar type in your IP address along with the periods and hit enter. If a box pops-up wanting a user-name and password you can add a note to this question and I will find for you because all isp's use different but generic for them.
In the router configurations your WEP will be in wireless security or wireless setup or wireless something. Just poke around but just don't change any settings unless you know what you are doing.
Good Luck!
1helpful
Write Message by Keypad
When you see soft keypad on screen while writing new message, click on the keypad icon at the bottom.
This should hide the keypad from screen.
Now you can type. The only problem is you can not type custom words. You have to depend on t9.
If you want to write custom work click on Add New word option. The word will be saved and t9 will recognize it when you try to type it again.
They keep telling me this when i try to login Incorrect Email/Password Combination Facebook passwords are case sensitive. Please check your CAPS lock key. You may also try clearing your browser's cache and...
The simplest solution is to type in the password into an empty area like your browser addressbar, check its a 100% correct and then cut and paste it into MySpace... If your cutting and pasting it from an email from MySpace, remember this doesnt always work as it sometimes adds extra spaces, so if you do this again cut and paste it into something, anywhere you like even word or notepad, make sure there are no extra spaces and then copy it again and paste it into MySpace :)
I would like to make a secure password for my outlook express as i have my lap top and my desk top in a room that can be accessed to. Thank you for your future concern
If you want to know what rules make up a good password - then try to think of a passowrd that has at least 6 - 8 charcters, is not a regular word and hard to guess for others, (not your favorite color or pet dog) also it should have a mix of capital letters regular letters, symbols and numbers. a phrase with spaces can be good -- LIke : "! W@nt 2 G0 $h0pping!" you also need to be able to remember it (not write it down) and not mess up too many times when typing it in.. Hope that helps.
To add a password to Outlook should be simple - I assume you know how to do that. oh but don't choose 'save my password' when you type it in or all that work will be for nought.
1helpful
I FORGOT MY ADMINISTRATOR PASSWORD
1. Log on with the account you have now.
2. Go to Start -> Run and type: cmd
3. When the CMD prompt opens, type the following:
net user Administrator <any password>
4. Press enter. A message should appear. Something like task completed or operation succesfull.
5. Close the screen, log off user.
6. Try logging in as Administrator again.
Where <any password> should be replaced with the password of your choice and types without the brackets. Also mind the spaces between the words. CMD assumes the word after the user accounts name is the password, but only when the user accounts name and the password are seperated by a space.
I hope this will answer your question, please don't forget to rate this solution.
Greetings,
DarkNeogen.,
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
