You need first to print the printer configuration list, you will see from which to which ip address you may connect. (example from192.168.1.1-192.168.1.13)
then you will set on your laptop or pc some address that is in the range of access control list, also set the printer ip address in the range of access control. than connect them to connect to the machine by and the laptop/pc with a FTP/LAN
(cross)cable or connect them with a network-switch. Then open a web browser on the laptop/pc and in the address bar write the ip address of the printer. it will open the web page of the printer, login with: user name: "admin" and password:"blank" . find the acces control setting and clear them. set them all with zero. (example: 0.0.0.0-0.0.0.0). if you need further help please write a replay.
SOURCE: Ricoh Aficio 1224c
Hello billboards,
SC 570 means that despite the fact that the the copier had been giving a "FUSER OIL LOW" prompt in the upper left hand corner of the display for quite some time, the prompt was ignored and now the oil is more than low it is empty. You will first need to aquire fusing oil for your machine.Typically it would be purchased from the same source you would aquire toner as it is something that is consumed as the copier is used similliar to toner. Once you have the oil you will need to replenish the copier's supply of oil. To do this you will need to access the back of the machine. Once you are at the back of the machine,look down to the lower right hand corner. You will see a small square panel with what I would describe as an oversized white plastic flathead screw that needs to be turned counterclockwise to release the small panel/cover. Once you remove the cover you will see a clear container witha black screw on cap. Unscrew it,and fill the container with the oil and stop filling when it reaches the neck of the container. Button everything back up and now you are halfway out of the woods. Now we go to the front of the machine. We need to reset the code. There is a yellow rectangular button above the nine key pad used to enter the number of copies you want. Now that you have located it, press it once and then press the "1" then the "0" then the "7" and then press the round red stop button and hold it down until the screen changes and beeps. At this point the display will have several blocks showing. One of the blocks will say "copier".Press the copier block. Now you will have a drop down menu to the left and several options across the top of the display. At the top,from left to right,the fourth box should say "SP DIRECT" and should actually already be highlighted. At this point,merely press "5810" on the keypad and then press the " # " pound sign. The pound sign means enter. At this point you should see a prompt that says something like "SC reset" and there will be a bar below the prompt that says "EXECUTE" .Press the execute button. This resets the code. But now you must turn the main power off (the red switch located next to your left knee on the front panel of the copier) and wait a few seconds. Now turn that switch back on and you should be good to go. I just reviewed my instructions and wanted to stress that the yellow button above the nine key pad says clear/stop. Just wanted to be more specific. I bet you have this problem whipped in no time! I hope this helps.Take care and good luck.And please feel free to let the folks at "FIX YA" know if I helped you. I don't get paid by them but I like the pats on the head . :-) ...........spinal.......
SOURCE: Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
please first tell me the model and than i will help you
