20 Most Recent Ricoh Aficio SP 9100DN Laser Printer Monochrome - 75 ppm Mono - USB - Fast Ethernet - Mac, PC Questions & Answers
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Ricoh Aficio SP... | Answered on Jun 11, 2016
This is a fuser fault code. First need to check and repair fuser. Buy a new or rebuilt fuser or replace items that cause problem could be thermistor needs to be replace to over temp sensor is bad and needs to be replace or lamp. Once replace then you can clear code. You can buy. Service Manual will explain how to get into service mode and reset fault code. Or post how to reset code on web
Ricoh Aficio... | Answered on Oct 05, 2018
print anable 6a
Ricoh Aficio... | Answered on Jun 01, 2018
When you replace developer, make sure to clean the waste toner path on the PCU. Waste toner in combination with new developer causes trouble. After replacement of the developer use a piece of paper to block waste toner from falling into the DV-Unit. Then run SP2-801 and do process control.
Then make 100 copies and after that remove the piece of paper. A Ricoh tech told me that the amount of toner in the developer can be very high, so he always made 100 copies before removing the piece of paper. I'm doing this for a long time and I never had trouble with SC's related to TD-sensor.
Ricoh Aficio... | Answered on Apr 07, 2018
You need to replace the HDD. It is very simple. Then format it in SP Mode. Reboot. Ready to use.
Ricoh Aficio... | Answered on Oct 30, 2017
Replace developer, clean ID sensor
Ricoh Aficio... | Answered on Aug 28, 2017
The machine will automatically reset the maintenance message when the fuser is replaced.
There is a looped wire on the fusing unit connector containing a thermo fuse (a thin wire that quicly melts, and then short the cirquit).
If you don't want to replace the fuser yet, you can probably set the machine to meter charge, SP mode 5930, and then reset the maintenance counter with SP mode 7804.
You can of course take out the fuser, and replace it with a dirt cheap thermo fuse bought from Ebay. Then set the fuser back into the printer, and it will clear the maintenance message automatically.
Either way should work fine, at least it used to do that on the previous model - and it is almost identical.
Ricoh Aficio... | Answered on Jul 06, 2017
where about is it jamming - copy 1 sheet and see where it stops.
Ricoh Aficio... | Answered on Jun 07, 2017
Ricoh Aficio SP 9100DN Laser Printer Monochrome - 75 ppm Mono - USB - Fast Ethernet - Mac, PC Logo
1 questions posted
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
make reset sc 544 ricoh aficio sp 9100dn
  • Office Equipment & Supplies
