Question about Ricoh Office Equipment & Supplies
I got error sc 554 for ricoh mp1600 - Ricoh Office Equipment & Supplies
Posted by girmay kassahun... on
ANIL KUMAR
    New Friend:
  • 22 Answers
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Posted on Oct 17, 2016
Ricohmachine mp 5055 has sc code 554
The Ricoh copier error code SC544 / 544 is a fusing lamp overheat error code. (This is a hardware problem)
This error can mean the:
PSU board is bad
IOB board is bad
BICU board is bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
Jul 03, 2018 | Office Equipment & Supplies
Ricoh mp1600 code144
this code is related to the scanner area . check if all cables are properly connected.
or the glass is fixed well
all the best.
Apr 08, 2016 | Ricoh MP1600 Copier
Error sc 554-02 ricoh printer
bad termistor in fusing unit. Call technical support
Aug 13, 2014 | Ricoh Office Equipment & Supplies
What Could Be The Failing Component On My Machine With Displays SC: 552 With An Error Message "Turn Off Main Switch And Then On" ?
I am no expert, but it potentially could be a memory chip error being a laser printer, very common, these can be easily and cheaply be replaced as there is usually an access hatch to the side printer memory isn't usually very high capacity
Jun 15, 2014 | Ricoh Nashuatec MP1600 Toner 9000 Yield...
Ricoh aficio mp1600 has an error saying toner not detected
says that toner almost empty after inserting new catridge
Mar 06, 2012 | Ricoh Aficio MP1600SPF Copier
I have ricoh aficio mp1600 & this machine is error occoured Sc:542 how to solve this problem?
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Dec 03, 2010 | Ricoh Aficio MP1600SPF Copier
Ricoh Aficio MP1600 Le
Is your Windows 7 a 32 or 64 bit? Which driver are you downloading? Recommend PCL5c...
Feb 10, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
My Ricoh CL2000n is getting the "SC 554" message and the power saving mode is turned off. Do you have any recommendations?
That is a fuser code and will not go away by turning the power off and on. The code needs to be reset in the service mode, and maybe a new fuser.
Nov 25, 2009 | Ricoh Aficio CL2000N Laser Printer
Open Questions:
628 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
