I have recently changed some of the ink cartridges - no reported problem.
Perhaps some nozzles in the head are blocked. Try printing some extra pages or the clean head procedure.
If it does not help, remove the cartridge where the nozzle(s) are blocked from and let one drop of cleaning fluid fall on the connection tube that goes into the cartridge (on the bottom of the cartridge holder) I get my fluid in a shop where they refill cartridges.
After you dropped the fluid, replace the cartridge and again let the printer clean the heads or just print a full colour page.
Success
SOURCE: I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
SOURCE: cartridge problem
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
SOURCE: BLACK PRINTOUTS ARE NOT CLEAR
The printer head is probably dirty or blocked.
You can run a head cleaning operation from the maintenance package which came with the printer.
SOURCE: IP5200 doesn't recognise cyan ink cartridge and
This is a fairly common problem. How long have you owned the printer and how long have you had this problem?
Once I have more information I can assist you further.
Thank you,
Lee
SOURCE: My Pixma MP 780 is printing sporadically, i.e. it
Hi! Only one thing can cause this. Please run head cleaning to get rid of the missing lines. This should be done every cartridge change. Hope this helps and thank you for using FixYa!
