SOURCE: Date stamp not transfering
As we know you should use the profetional movie making software so you will be able to do the stamp of date.
SOURCE: need help on setting the date and time when you record it into dvd.
You need to add a data code. put your camera into play/edit. choose MENU>DATA CODE.
SOURCE: Time and Date does not display after importing files to my computer
Hi LAShamus, have you already configure your Time and Date?
SOURCE: DAte/Time stamp
I was having the same problem, and was tasked to find a solution at work.
I ended finding talking with a developer who wrote a custom utility that can extract the time/date data from the .MPG (it's hidden in there somewhere) as a special txt file.
Here's a link to that utility: (special version for NTSC footage):
http://dl.free.fr/pNo24JrdB
(Special thanks to fnx91 on the videohelp forums)
Then you import that file into a piece of software called DVSubmaker which will convert that data in a special format (.sub) used by certain DVD/Video players to display subtitles.
Here's the best 2 options for playback:
1. Windows Media Player (need Mpeg2 codec) combined with a plugin called Vobsub - Free:)
2. ZoomPlayer (DVD Software) - $60
So in a nutshell, your displaying the original time/date stamp as subtitles on top of the video.
Contact me if you have any troubles.
SOURCE: MY COMPUTER DOES NOT DETECT
Here's the USB driver for your camera:
http://www.helpdrivers.com/ingles/listado/dow.asp?codigo=81834
Click download (middle of page) . Run this driver . After that connect
your handycam. Now your pc will recognize your handycam and be ready to use.
Good luck !
Chris (ziraffa)
